POV Bauble Uses DIY Accelerometer To Sync The Image
So we saw this tip come in and thought–oh, another POV device. We watched the video (embedded after the break), took a sip of coffee, then almost sprayed the beverage all over the computer when we realized that this uses a diy sensor to synchronize the POV image.
[Ch00f] came up with the idea for the sensor after seeing a similar implementation on a commercial POV toy. Instead of using a proper accelerometer to sense the motion, the toy uses a plastic bead in a channel. When you move the body of the toy the bead rolls to one end or the other, covering or exposing a reflective sensor.
A similar sensor is used here. A drinking straw servers as the channel, with a paper-covered nylon screw as the bead. [Ch00f] cut a window in the bottom of the straw for his reflective sensor, then sealed each end with a wad of paper.
This method works, but not as well as he had hoped. It seems the refresh rate and timing of the particular sensor he’s using is rather poor. If it were replaced with one that is simply and IR LED and phototransistor (like the sensors from [Jack’s] last video) he thinks it would work a lot better.
via Buildlounge.
[youtube=http://www.youtube.com/watch?v=v_juUcHVYZo&w=470]
6 thoughts on “POV Bauble Uses DIY Accelerometer To Sync The Image
  1. When I build a POV device in my freshman year, I just used a simple microswitch with a small lever with a nut glued to it, and a small steel frame with adjusting screws to prevent the switch from breaking.
Leave a Reply to SparkyGSXCancel reply
