Browser-based Circuit Simulator Boasts A Mountain Of Features
CircuitLab is an electronics simulator which you can run in a browser. Above you can see one of the example circuits provided to help show the power of the application. You can build your schematic (perhaps you want to try [Jeri’s] psu shut-off timer?) in the editor mode, then switch over to the simulator to get data back from the components. In that mode, your cursor becomes a probe, and clicking on different parts of the circuit will return the calculated input and output voltages for that component. But wait, there’s more. It’s got time and frequency simulation in addition to the voltage simulator. This lets you look at waveforms fed through analog filters, or timing data like in the 555 timer circuit above.
Where does this fantastic tool come from? [Humberto Evans] and [Mike Robbins], the guys behind NerdKits developed this site. We’ve seen a lot of their hacks around here, like milling solenoids and making them play a xylophone. Check out the CircuitLab quick start video they put together after the break.
[Thanks Brian]
22 thoughts on “Browser-based Circuit Simulator Boasts A Mountain Of Features
  1. Man, you guys have been on a roll lately with posts on things I’m interested in (3D Scanners, circuit diagrams). Another super useful post for something I’ll be playing around with this weekend.
    Keep up the awesome!
  2. My lock-in-attempt-detector just went full scale.
    Beware: the service wont stay free forever and currently doesn’t allow exporting to other software.
    I would rather stick to Qucs, NGspice and many other free simulation software that won’t force me to either sign in somewhere or stay connected, and won’t attempt to lock me in.
  3. Now what would be totally cool would be to merge this with the Arduino IDE and chips so you can built your circuits and test your programming all in one. This is neat for dumb (no microcontrollers) circuits though!
  4. That’s pretty amazing. On a <1Mbps connection it only took about 5 seconds to load.
    I like things like EAGLE and all of those design programs, but this seems like it's simpler to use, more powerful for simulation, and most importantly free.
    Love it.
    1. So they opened up the first MITx 6.002x electronics class online today, and it turns out the ‘circuit builder’ tool they have as part of that course is almost EXACTLY this program verbatim.
      It’s got some differences cosmetically, but the how-to is the same, the controls, the placement. It’s pretty damned solid.
  5. This is porn!
    We use NI MultiSim and this seems just so much better! (And i don’t have to start windows to run it on my macbook)
    Graphically its a thing of beauty compared to the NI tool, and it’s so much faster to build circuits!
  6. Those of you who have signed up and can create/edit circuits, what browser & version number are you using?
    I signed up but it won’t run on FF3.6 & FF4, I gave up upgrading FF beyond 3.6 on most of my PCs because they kept dicking around with the layout, altering the look and screwing with the menus to the point where I had to spend half an hour just messing with the config & installing plugins on v4 just to get it to look and behave the same as 3.6.
      1. Weird, I just tried it again on FF3.6 and it works fine. The last time I tried was a couple of days ago when I signed up. Something must’ve changed, whatever it was means I can now start using it.
Leave a Reply to Will Cancel reply
