ATtiny Controlled Magic Eye Tube
In the early days of broadcast radio, the most expensive radio sets were extremely impressive pieces of furniture. With beautifully crafted wooden cases polished to a high shine, these wireless receivers were the focal point of any family room. Some of the most expensive radio sets even included a visual indicator signaling the strength of the reception, something [Marcus] decided to re-engineer using an ATtiny85.
The display tube in question is an EM800 magic eye tube, used in radio sets, stereos, and electronic test equipment as a rudimentary display indicator. By applying a control voltage (from 0 to -10V), the illuminated display can be controlled like a bar graph display.
[Marcus]’ tube display is built around an ATtiny85 microcontroller, using a homemade PCB. It’s a fairly simple build, once the issue of supplying 250 Volts to the EM800’s anode is taken care of.
In the video after the break, you can see the bar display of [Marcus]’s magic eye tube slowly growing and receding, perfect for either displaying the current CPU load on your computer or anything else a dynamic bar graph display would be used.
9 thoughts on “ATtiny Controlled Magic Eye Tube
  1. A spectrum Analyzer wouldnt be to difficult.
    Just program the Tiny85 to detect one particular Frequency with its ADC Input (Goertzel or Wave Digital Filter or whatever) and do this for 8 different Frequencies. There are even implementations of FFT for Atmel controllers…
  2. One of the most common applications of “magic eyes”, or electron-ray tubes as they are known, was as recording level or VU indicators in tape recorders. They are more robust than a moving coil meter, much faster in response, and were available in a range of display formats.
Leave a Reply to AussieTech Cancel reply
