How A Quarter Shrinker Works
This machine is capable of shrinking coins. What you’re looking at is actually a 3D model of the Geek Groups impulse generator, which is called Project Stomper. The model is used to explain how induction shrinks a quarter to the size of a dime.
The grey chamber to the left is a reinforced containment device. It’s a safety feature to keep people in the same room as the Stomper safe from flying particles which may result from the forces this thing can put out. You see, it uses a mountain of magnetic energy to compress the edges of a coin in on itself.
As the video after the break illustrates, the main part of the machine on the right starts off by boosting mains voltage using a microwave oven transformer. This gets the AC to 2000V, which is then rectified and boosted further to get to 6000V DC. This charges three huge parallel capacitors which are then able to source 100,000A at 6 kV. When it comes time to fire, the charge is dumped into a coil which has the coin at its center. The result is the crushing magnetic field we mentioned earlier.
This isn’t a new concept, we featured a different coin crusher build in the early years of Hackaday’s existence.
43 thoughts on “How A Quarter Shrinker Works
  1. Forgive my ignorance, when the coin gets smaller, what happens to it’s internal structure? Do the atoms and molecules get squished closer together? I’ve never really understood density. Like, how can steel be less dense than lead if they are both completely solid. Magic?
    1. The volume is still the same. Although it’s smaller in diameter, it becomes a bit fatter.
      I would like to see someone work out how to make a CNC sheet metal forming machine using electromagnetic impulses.
    2. we had the local university do some Rockwell testing on the quarters shrunk. there is a noticeable (if .1 rc is noticeable) amounts of hardening of the material. Compression did take place, as well as deformation. Its small enough that you’d need an incredibly accurate graduated cylinder (or other volume measurement solution) to see, but the implication of the hardness changing in the material implies the material had to ‘shrink’
      incidentally, there is testing currently in theoretical energy solutions where they’re using essentially the same system, scaled up, to compress material to create higher yields per volume.
    3. Also, the way solid materials have different densities: the atoms that comprise those materials are different sizes, and the inter-atomic spacing of the atoms in the crystals have different equilibrium lengths.
  2. Help me out here.. How does a “crushing electromagnetic field” crush this non-iron object?
    Or is it that the induced currents just heat it?
    1. magnets don’t just effect ferrous metals. Depending on the strength of the magnet, just about anything can be effected in one way or another. If you want to test this, make a pendulum out of aluminum foil and swing it from side to side. then do it again under the same conditions but put a neodymium magnet beside the path of the pendulum. it will go ALLOT slower
      1. That would be, specifically, demonstrating eddy currents. Eddy currents occur when a magnetic field pulls on the electrons in a conductor, IIRC. And, since everything is somewhat conductive, voila.
        FYI this is how generators work. The windings of copper match the flow of the eddy currents, turning mechanical work on the magnet into moving electrons.
    2. I love coin shrinkers, I really do! I just can’t get over the fact that they are machines that cost thousands of dollars that literally eat money and poop out condensed slugs with images of presidents as if they aged 30 years. hey if you put a glass of water in it would you get a block of ice?
      1. Not intentional to poop on their parade, but…
        “Defacement of currency is a violation of Title 18, Section 333 of the United States Code. Under this provision, currency defacement is generally defined as follows: Whoever mutilates, cuts, disfigures, perforates, unites or cements together, or does any other thing to any bank bill, draft, note, or other evidence of debt issued by any national banking association, Federal Reserve Bank, or Federal Reserve System, with intent to render such item(s) unfit to be reissued, shall be fined under this title or imprisoned not more than six months, or both. ”
        http://www.moneyfactory.gov/historicallegislation.html
        They recorded themselves and posted it online.
        1. You’re quoting “historical legislation” which is perhaps no longer valid?
          “In the U.S., those laws specify the violation must include “intent to defraud,” while other countries prohibit any use of their currency other than its intended purpose.”
    3. there’s a lot of articles out there that explain how aluminum slugs are the choice ballistic solution for naval coil guns currently in production…
      meanwhile, the way i understand it, the 10 turn coil is actually like a transformer, and the coin represents a single turn. Between getting very hot (the coins are almost too hot to the touch immediately after a discharge) and the emf fields, the coin collapses in on itself, or rather, its magnetic field.
      http://dvice.com/archives/2012/02/navy-fires-up-f.php
      instead of trying to accelerate a mass out of a barrel, imagine trying to hold that mass in place and subject it to those same forces uniformly.
      meanwhile, The Geek Group does have another impulse generator:
      http://www.youtube.com/watch?v=cA0i8OPAqDA&feature=plcp
      that can send a non magnetic aluminum can soaring, imparting so much force that the can, while not in motion, resists the acceleration to the point that its bottom caves in. That unit also turns harddrive platters into funnels … there’s a particularly amusing point where a plastic pony (yes, my little pony) sitting on the ring offers enough resistance that the ring fails under its feet and the legs are sticking through. meanwhile, the only mechanical motion in that device is the high voltage contactor to discharge the circuit. long story short, there’s a incredible amount of energy being discharged in a very short window of time, and we’re able to capture that and do some amazing things with it… which is the point of being a geek.
  3. There must be a better application for this than mangling a quarter. Is the effect the same for objects of homogeneous material (say a steel slug), rather than the sandwiched materials from which quarters are made?
    The graphics are nice tho….
  4. So if you ran a coin through this enough times you would get a ball or a rod? Or maybe an hour glass? That is a ton of power. How efficient is this compared to a press and hydraulic motor?
  5. This isn’t very convenient for those of us that need to shrink things whilst on the go, but I’m sure this will be overcome once they release a handheld version
    1. Agreed. And where’s the Bluetooth connectivity? NFC reader? It’s just missing so many features, I feel it’s not a complete product.
      1. if i had a spare arduino w/ a wifi shield on it, i could make that all happen… but i’m pretty sure sensitive electronics that close to the discharge might not fare so well… it’d work the first time at least.
  6. hey guys, i have the pleasure of being on the team that developed this particular crusher, and i’m excited to see it receive such a popular response. We have run coins multiple times in the system, but after the first go they have a tendancy to destroy the cap blocks that hold them in the coil. We’ve also shrunk tube stock in the machine, with very interesting results. Stomper, being the Mark IV variant of the machine was developed specifically to shrink coils, and we’re already working on V and VI variants, though the powers that be don’t want me to say anything about those :) The first three MKs of this build were strictly testing of the capacitors and charging circuits. MK3 didn’t have the benefit of a blast containment, and i am the proud owner of a shirt that has an interesting gash in it where a peice of the copper coil decided it was time to illustrate why that was an important feature.
    of all the comments i see, nato, yours amuses me the most. consider it done. There’ll be, come hell or high water, a video demonstrating the magnetic prowess of 1.21 gigawatts.
  7. With the understand nothing can be perfect,I’d have to say the geek group may have created the ultimate hackerspace. I really don’t keep up to date on their projects, so I wonder if this is a new reiteration of thumper. The animation doesn’t resemble the last thumper I have seen. This might be the portable version they mentioned they where working on. In any event they are an awesome devices that store & discharge an awesome amount of potential electrical. energy. The comparison of the capacitor bank charge & discharge times is an interesting fact.
    1. This is Stomper, Thumper’s still there. The portable version you heard about, Kicker, was finished about two months ago. A portable ring launcher, Tosser, was finished last week. So The Geek Group now has four impulse generators.
      Oh, and as to squishing. A member took a quarter into his college metallurgy lab and found the “Rockwell Number” increased a bit. In theory that means the volume decreased “a little bit” :)
    2. Hey there guys. This is Stomper, not Thumper. The portable version is Kicker (a smaller version of Thumper). I’ve submitted links of all of the recent projects to HaD and haven’t seen any post or gotten any responses. The Geek Group is certainly interested in sharing with HaD and I would welcome a contact there to get a hold of for submissions and first peeks at our latest work.
  8. Pretty damn cool. Now I know how to shrink coins should the need arise.
    Incidentally, I watched some of the Geek Group videos on YouTube earlier today. Anyone else find Chris Boden to be a more-annoying version of Kevin Rose?
  9. If you invert the flux capacitor you can drain a liquid from it that when rubbed on 20 dollar bills turns them into 50 dollar bills.
    But I guess they can’t mention that for legal reasons.
  10. I’ve always wondered why the principle wasn’t combined with the Farnesworth Fusor, just to see if you can create “pulse fusion” instead of the nice little orbits you see whenthey operate in star mode… not saying it would increase useful energy production – but you might increase output.
    1. I like your Farnsworth fusor idea. I have read a little about laser-on-foil very simple particle accellerators that use a very brief, but very high energy laser pulse to make A,B,Y radiations as well as nucleus fragment radiation and possibly other radiation things from just pulsing a laser on a thin foil. So, noting the coin squisher, could they time the moment of the laser picosecond, or femtosecond percussion of the foil when the foil is at its thinnest from the quartersquisher compression field and the possible temporary densification of the metal foil, you might get entirely different physics particles, and energies and even particle forms out of it. It matters for oil and geological prospecting and seeing through shipping containers. You might have read about x ray fluorescence guns that geologists use in the field to characterize and map any kind of mineral finds. with a laser-foil emitting a different radiation, different minerals and elements can be detected and mapped, like think of a drone flying around and being able to map elements and minerals an _order of magnitude deeper_ from using more energetic particles, and particles different than x rays
    2. Your farnsworth fusor idea is nifty, it reminds me of another high energy plasma particle accellerator you might have heard of called a laser wakefield array, these, at just 200cm long are at 1/5th, or maybe now higher, of the particle accelleration capability of an electromagnetic multiKm loop accellerator, laser wakefield arrays have a plasma that seems likely to be very able to be purposefully highly compressed with a quartersquisher magnet.
    1. It’s better than that. Inflation will cut 2 or 3 % off the value of your money, but this machine will slash it by 100%!
      That’s the future, guys!
Leave a Reply to Scott L. SammonsCancel reply
