Extreme Game Boy Hack Plays Titles From A Wide Range Of Systems
gameboy-ds-in-original-gb-case
[Akira] can play any Game Boy, GBC, GBA, NES, SNES, or SMS game while on the go thanks to all the work he put into this portable gaming hack. The outside seems familiar; it’s an original Game Boy case. But you should immediately notice that it has a few extra buttons. That’s the first clue that what’s inside isn’t stock… which is a huge understatement.
The idea for the project started off rather simple, but quickly got out of hand (check out the build log for full details on that). He thought it would be nice to have a backlight for the original screen. After mixed results he scrapped the original mainboard and started anew with some Nintendo DS Lite hardware. It had a broken LCD connector so he tried a couple of different fixes to get it working again. After some success he started adding more equipment, like the extra pair of buttons, a better speaker on the battery door, and the microSD add-on you can see above.
You can catch a demo of the finished goods after the jump.
Continue reading “Extreme Game Boy Hack Plays Titles From A Wide Range Of Systems”
ShuttAVR Can Snap A Pic Or Serve As An Intervalometer
shuttAVR-intervalometer-hack
This project started as a simple microcontroller replacement on this IR camera remote control PCB. But the soldering job went rather badly for [Balthamos] so he changed things up and designed his own simple AVR remote shutter release and intervalometer.
The DIP chip seen with most of its legs bent backwards is the ATtiny25 which makes the system work. It’s patched into the traces for the battery connections, button (on the other side of the board) and the IR LED he’s pinching with his left hand. Point it at a Cannon camera and push the button to snap a photo. But as you can see in the clip after the break it also serves as an intervalometer; letting him take several pictures with a user-defined pause between each. That mode is selected by first pressing and holding the button. Once released the chip waits for a second button press to register the delay. The new circuit still fits in the original case after just a bit of alteration to it.
Continue reading “ShuttAVR Can Snap A Pic Or Serve As An Intervalometer”
