Atari 800 EPROM Cartridge Hack
atari-800-eeprom-hack
[FozzTexx] had an old Atari 800 collecting dust and decided to pull it out and get to work. The problem is that it’s seen some rough storage conditions over the years including what appears to be moisture damage. He’s read about a cartridge called SALT II which can run automatic diagnostics. Getting your hands on that original hardware can be almost impossible, but if he had a flashable cartridge he could just download an image. So he bought the cheapest cartridge he could find and modified it to use an EPROM.
When he cracked open his new purchase he was greeted with the what you see on the left. It’s a PCB with the edge connector and two 24-pin sockets. These are designed to take 4k ROMs. He dropped in an EPROM of the same size but the pin-out doesn’t match what the board layout had in mind. After following the traces he found that it is pretty much an exact match for an Intel 2764 chip. The one problem being that the chip has 28-pins, four too many for the footprint. The interesting thing is that the larger footprint (compared to the 2732) uses all the same pins, simply adding to the top and moving the power pins. A small amount of jumper wire soldering and [FozzTexx] is in business.
5 thoughts on “Atari 800 EPROM Cartridge Hack
  1. I made use of the same Pin-similarity back in the 90ies when I wanted to modify the ROM of my VGA card or make Ethernet cards bootable without an EPROM burner. It turns out that conveniently accessible Flash Eproms that could be written to either in the mainboard (by hot-swapping) or in more modern network cards had a similar layout as the 32k ROMs of my VGA card. An Adapter sucket is easily built out of 2 sockets stacked on top of each other and 2 wires.
  2. I have about 30 of them cartridge boards like that from 1978 through 1982 that are never used Brand New old stock if anybody would be interested in them I don’t even know if I’m allowed to comment like that but I mean if not let me know when I delete my reply or you guys can just take it down or whatever I just thought I’d throw that out there
      1. I just now seen that I had a reply to my post look me up on Facebook messenger under the name Jr Saints and I will send you some pics of what I have I do have a few other Atari computer chips as well let me know as soon as possible I have 2 other people who say they are interested so please get with me soon thanks
Leave a Reply to fooCancel reply
