Computer Controlled Water Show
watershow
After seeing our recent post on Laminar Flow Nozzles, [Richard] decided to share with us his family’s summer project — a computer controlled water show (translated)!
The setup uses a Raspberry Pi at its core and a set of USB relay boards to turn the valves and lights on and off to the music. They wrote the program in Python and have posted it on their website to share.
They used common household solenoid valves because they are easy to control by relay, but unfortunately they are on/off only, so variable flow is not possible. A challenge they encountered was equalizing the water pressure — one to make sure the pump didn’t over heat when the fountains were off, and two, to equalize the height of each fountain stream. To solve this they used a pressure regulator for the pump, and organized the plumbing in such a way with additional control valves that the pressure differences were minimal.
The setup doesn’t sound like it cost that much, and now the family has their own music activated water fountain in their garden — how awesome is that! Stick around after the break to see it in action.
Here’s the link to the recent laminar nozzle project we mentioned above. Maybe as a future upgrade they could take some ideas from these laminar flow jets to make the streams behave more like fiber optics!
4 thoughts on “Computer Controlled Water Show
  1. So very cool! I can’t wait to see the combination of the illuminated laminar flow jets and this… which I’m sure several readers of this site are already dreaming of, planning, or actually working on.
    But am I the only one bothered by the sound of the water landing? Since it’s not in sync with the music it messes up the flow, so to speak — or at least in my OCD head. To me it seems silly to try and sync the landings too (don’t even know how you’d try), but on this small of a scale (size and sound volume) it seems to matter more. Could’ve just been the video though.
    If it had a small jet in the corner which is constantly going so there’s always the sound of water landing…maybe the individual “splats” wouldn’t be as jarring to my easily confused and side-tracked mind.
    Just nit-picking though. Awesome build.
Leave a Reply to EricCancel reply
