Network Controlled Decorative LED Matrix Frame
LED-Pixel-FrameThere is nothing better than a project that you can put on display for all to see. [Tristan’s] most recent project, a Decorative LED Matrix Frame, containing 12×10 big square pixels that can display any color, is really cool.
Having been built around a cheap IKEA photo frame this project is very doable, at least for those of you with a 3D printer. The 3D printer is needed to create the pixel grid, which ends up looking very clean in the final frame. From an electronics perspective, the main components are a set of Adafruit Neopixel LED strips, and an Arduino Uno with an Ethernet shield. The main controller even contains a battery backup for the real time clock (RTC) when the frame is unplugged; a nice touch. Given that the frame is connected to the local network, [Tristan] designed the frame to be controlled by a simple HTML5 interface (code available on GitHub). This allows any locally connected device to control the frame.
Be sure to check out the build details, they are very well done. If you are still not convinced how cool this project is, be sure to check out a video of it in action after the break! It makes us wish that you could play Tetris on this frame. Very nice job [Tristan]!
9 thoughts on “Network Controlled Decorative LED Matrix Frame
  1. Is it IP65? Think about what will happen if someone (for example a child or your wife) decides to urinate on this thing. They could get a nasty shock!
  2. Nice article, thanx !
    If anyone is in Paris, I will present this project among others at the Maker Faire Paris tomorrow.
Leave a Reply to LKCancel reply
