A 16-voice Homebrew Polyphonic Synth
Homebrew synths – generating a waveform in a microcontroller, adding a MIDI interface, and sending everything out to a speaker – are great projects that will teach you a ton about how much you can do with a tiny, low power uC. [Mark] created what is probably the most powerful homebrew synth we’ve seen, all while using a relatively low-power microcontroller.
The hardware for this project is an LPC1311 ARM Cortex M3 running at 72 MHz. Turning digital audio into something a speaker can understand is handled by a Wolfson WM8762, a stereo 24-bit DAC. Both of these chips can be bought for under one pound in quantity one, something you can’t say about the chips used in olde-tyme synths.
The front panel, shown below, uses 22 pots and two switches to control the waveform, ADSR, filter, volume, and pan. To save pins on the microcontroller, [Mark] used a few analog multiplexers. As far as circuitry goes, it’s a fairly simple setup, with the only truly weird component being the optocoupler for the MIDI input.
goom2
The software for the synth is written mostly in assembly. In a previous version where most of the code was written in C, everything was a factor of two slower. Doing all the voice generation in assembly allowed for twice as many simultaneous voices.
It’s a great project, and compared to some of the other synth builds we’ve seen before, [Mark]’s project is at the top of its class. A quick search of the archives says this is probably the most polyphonic homebrew synth we’ve seen, and listening to the sound sample on the project page, it sounds pretty good, to boot.
11 thoughts on “A 16-voice Homebrew Polyphonic Synth
  1. I like the idea of having the analog muxes directly at the frontpanel pcb in order to reduce the number of connections between the pcbs.
    1. I agree, many synth homebrewers chose this route (e.g. Audiothingies P6, Sonic Potions LXR, PreenFM2). But, this would not have been as cheap.
  2. Fantastic work getting the polyphony going :-) I’ve been messing around with this recently on an stm32F4-discovery:
    github.com/MrBlueXav/Dekrispator
    Monophonic but it has lots of strengths and a lot of potential, lots of oscillators, dual filters, control via usb midi (works standalaone with a usb midi keyboard), no external parts necessary (apart from a keyboard)
Leave a Reply to reggieCancel reply
