Whiteboard Clock Draws The Time
Whiteboard Clock
[Maurice] recently built a clock that draws the time (Google Doc) on a white board. We’ve seen plenty of clock hacks in the past, and even a very similar one. It’s always fun to see the different creative solutions people can come up with to solve the same problem.
This device runs on a PIC16F1454 microcontroller. The code for the project is available on GitHub. The micro is also connected to a 433MHz receiver. This allows a PC to keep track of the time, instead of having to include a real-time clock in the circuit. The USB connector is only used for power. All of the mounting pieces were designed in OpenSCAD and printed on a 3D printer. Two servos control the drawing arms. A third servo can raise and lower the marker to the whiteboard. This also has the added benefit of being able to place the marker tip inside of an eraser head. That way the same two servos can also erase the writing.
The communication protocol for this systems is interesting. The transmitter shows up on [Maurice’s] PC as a modem. All he needs to do to update the time is “echo 12:00 > /dev/whiteboard”. In this case, the command is run by a cron job every 5 minutes. This makes it easy to tweak the rate at which the time updates on the whiteboard. All communication is done one-way. The drawing circuit will verify the checksum each time it receives a message. If the check fails, the circuit simply waits for another message. The computer transmits the message multiple times, just in case there is a problem during transmission.
3 thoughts on “Whiteboard Clock Draws The Time
  1. [Bdolge] wishes to make it clear that while he submitted the hack in question to Hackaday, it is actually the work of Maurice Bos who is much smarter and cooler than myself and creates the sort of amazing stuff I admire but rarely achieve.
  2. “The micro is also connected to a 433MHz receiver. This allows a PC to keep track of the time, instead of having to include a real-time clock in the circuit.”
    Hmm, sending a clock signal from an RTC on a PC over 433MHz seems a tad convoluted. I guess Maurice didn’t have an RTC on hand?
Leave a Reply to RedbackCancel reply
