RGB LED Ceiling Display
yP8PoVDisco Floor’s are passé. [dennis1a4] turned them upside down and built an awesome RGB LED ceiling display using some simple hardware and a lot of elbow grease. His main room ceiling was exactly 32 ft x 20 ft and using 2 sq. ft tiles, he figured he could make a nice grid using 160 WS2812B RGB LEDs. A Teensy mounted in the ceiling does all the heavy lifting, with two serial Bluetooth modules connected to it. These get connected to two Bluetooth enabled NES game controllers. Each of the NES controller is stuffed with an Arduino Pro Mini, a Bluetooth module, Li-Ion battery and a USB charge controller.
Bluetooth is in non-secure mode, allowing him to connect to the Teensy, and control the LEDs, from other devices besides the NES controllers. The Teensy is mounted at the centre of the ceiling to ensure a good Bluetooth link. Programming required a lot of thought and time but he did manage to include animations as well as popular games such as Snake and Tetris.
LED_Ceiling_deadbugThe hard part was wiring up all of the 160 LED pixels. Instead of mounting the 5050 SMD LED’s on PCBs, [dennis1a4] wired them all up “dead bug” style. Each pixel has one LED, a 100nF decoupling capacitor, and 91 ohm resistors in series with the Data In and Data Out pins – these apparently help prevent ‘ringing’ on the data bus. Check the video for his radical soldering method. Each SMD LED was clamped in a machine shop vice, and the other three parts with their leads preformed were soldered directly to the LED pins.
The other tedious task was planning and laying out the wiring harness. Sets of 10 LEDs were first wired up on the shop bench. He then tacked them up to the ceiling and soldered them to the 14 gauge main harness. The final part was to put up the suspended ceiling and close the 2 sq. ft. grids with opaque plastic.
[dennis1a4]  did some trials to figure out the right distance between each LED and the panel to make sure they were illuminated fully without a lot of light bleeding in to adjacent panels. This allowed him to get away without using baffles between the tiles.
Check out the video to see a cool time-lapse of the whole build.
8 thoughts on “RGB LED Ceiling Display
  1. It is very neat to see this much amount of documented build time in one place, Thanks a ton hackaday and especially dennis1a4
  2. Why do you need two bluetooth modules on one Teensy? BT is not point-to-point. You can connect both controllers through one module (“personal area network”).
    1. probably because he was using bluetooth serial modules. you can connect to one module at a time with the stock firmware, so the easy solution is to just use 2 of them since they’re about $5 a piece.
  3. Wow all that soldering. I would have just bought the NEOPIXEL china knockoffs on ebay for $1.00 each.
    Although I bet he is an expert at perfect soldering of deadbug 2812’s now!
  4. I’m pretty sure you meant 2 feet square, not 2 sq ft for the size of the tiles…
    so a 32ftx20ft cieling = 640 sq ft, / 2 sq ft = 320 pixels, not 160. 640 sq ft / 4 sq ft = 160 pixels as the article claims.
    a square tile 2 feet on a side (“2 feet square”) is a 4 sq ft pixel…
