Full-size AT-ST Star Wars Build
Think you made a cool tree-house for your kids? Sorry to burst your bubble, but we don’t think anything can top this full-size 1:1 replica of a Star Wars AT-ST — complete with sound effects and moving turrets! Did we mention it seats two?
Built in his backyard, this AT-ST is constructed of wood, plastic, and sheet metal. On the inside it is decked out with joysticks, display panels, and other knobs and buttons for your imagination to go wild with. It even features solar panels on the roof to power two ventilation fans to keep you cool while daydreaming of blowing up Rebel scum on Hoth.
Stay tuned after the break to see a video of it in action.
Continue reading “Full-size AT-ST Star Wars Build” →
The Ultraviolet Catastrophe
As the light of the 20th century was peeking over the horizon, a young physicist by the name of Max Planck was taking to heart some career advice he had received while he attended Munich University in Germany. With the recent discovery of thermodynamics, there wasn’t much left in physics to know, or so his adviser thought. Hindsight is indeed 20/20.
It turns out that Planck was an expert at thermodynamics. Having mastered the subject gave him some leverage to use against a growing group of physicists known as atomists who were using statistical models along with so called ‘atoms’ to predict experimental outcomes. Atomists believed that matter was composed of discrete units. Planck believed the world was continuous and could not be divided into any type of discrete component. And he would draw the second law of thermodynamics from his holster and put this atom idea in the clay.
Continue reading “The Ultraviolet Catastrophe” →
Screw Drive Tractor Hasn’t Conquered Canada Yet
[REDNIC79] lives somewhere in Canada where key terrain features include mud and snow. Half pontoon boat, half auger, screw-propelled vehicles excel in this kind of terrain as long as you’re okay with going really slow.
In his 11-and-counting part video series, [REDNIC79] goes through the conversion of a lawn tractor into a slow, theoretically unstoppable, Canadian screw-propelled tractor. He welds a frame, plonks some beefy chains on it, and throws a few hefty looking bearing mounts on there to boot. Then he makes some screws out of gas tanks; which was an enormous amount of work.
It was time to fire up the tractor. On the first muddy incline encountered, the tractor ceased to move. The culprit? A cracked transmission housing. Ouch. The end of the shaft holding the chain for the right screw was unsupported. When the shaft turned, it imparted its rotational force, but there was also an unconsidered down force on the end of the shaft, which resulted in a moment the bell housing wasn’t designed for.
Undeterred, [REDNIC79] welded the housing back together and threw a bearing on the end of the offending shaft to balance the moments. He fired it up, engaged the transmission, and the right screw bearing pillow block completely shattered. Ouch again. We can safely begin to assume that screw-propelled vehicles see a lot of forces.
[REDNIC79] hasn’t shelved the project yet. His next plan is to beef up the supports and build a much larger set of screws with smaller blades out of some propane tanks. This should reduce the force the power house needs to put out. Video of the first fail after the break. Continue reading “Screw Drive Tractor Hasn’t Conquered Canada Yet” →
3D Printing A Fake Product Leak
A few days ago you might have seen images floating around the net of the next Nintendo console controller, The Nintendo NX. There were so many pictures, it just had to be real!
Wrong. It was just [Frank Sandqvist] messing with everyone on the Internet. While phony product leaks are usually just photoshopped or 3D modeled renders, [Frank] took it a step further and actually designed a whole controller, 3D printed it, and took pictures of it. You might be wondering why he would do this. As a Reddit user points out there could be an excellent motive behind it:
You could also use it to get a job as a prop maker. It would look awesome on a CV that you made a prop that fooled the world — [Critters]
But, according to [Frank] it was really just for fun.
Continue reading “3D Printing A Fake Product Leak” →
