Automatic Pneumatic Harmonica
A wise man once said “If all you’ve got is a cute desktop compressor and some solenoid valves, everything looks like a robotic harmonica.” Or maybe we’re paraphrasing. Regardless, [Fabien-Chouteau] built a pneumatic, automatic harmonica music machine.
It’s actually an offshoot of his other project, a high-speed candy sorting machine. There, he’s trying to outdo the more common color-sensor-and-servo style contraptions by using computer vision for the color detection and a number of compressed-air jets to blow the candy off of a conveyor belt into the proper bins.
But before that gets rolling, a test of the computer-controlled pneumatic setup is in order. And that’s where the harmonica entered the picture. The “build” is really just him putting the tubes from the candy sorter into a harmonica. There’s an ARM processor spinning its high-powered wheels, and some MOSFET drivers to open and close the valves. But that’s it. Watch it play a “tune” in the video below.
We love wacky instruments, robot anythings, and serendipitous spin-offs. What’s the coolest project that you’ve made that wasn’t the main project, but just a step along the way? Did you plan it in advance or did it just happen? Did you have the guts to post it like [Fabien]? Can we encourage you?
17 thoughts on “Automatic Pneumatic Harmonica
  1. lol k…
    i had an idea for something like this,… but with a slide whistle… a servo controlling the whistle length and air pressure to the whistle with a solenoid valve
    had it working with tests but no air compressor,.. maybe i’ll try again
    1. I might go with something like a hard drive voice coil rather than a gearmotor servo. It should be able to produce a much smoother transition with less added noise to the result. Maybe a spring loaded solenoid would work, just use driver with controllable current and you should be able to position it.
      1. That is a brilliant idea with the hard drive voice coil! I think it would work quite well attached to a plunger or syringe with a spring added to bring the actuator back on its own. A little less gaudy than the air compressor lol. I could imagine a calliope / organ could be also made in a similar manner.
  2. I wanted to do something similar with Bagpipes! For some reason the other members of my house were not in favour of me developing this instrument! :)
      1. To discourage door-to-door salesmen, you could Design the system to require them to hand pump the air required to make the doorbell work! ;-)
  3. Hmmm … might be a while before the robot can headline a Led Zep cover band doing “Nobody’s Fault But Mine”.
Leave a Reply to Pierre Baillargeon (@Kabong)Cancel reply
