If binary clocks have you confused by all the math required to figure out what time it is, we have the solution for you: a unary clock. After all, what’s simpler than summing up powers of two? Powers of one! To figure out the time, you start with the ones digit. If it’s on, you add one to the total. Then move on to the next digit. Since 12 equals one, you add another one if it’s lit. Then on to the third LED. 13 = 1, so if it’s lit, you add another one, and so on.
OK, we’re messing around. Calling this a “unary” clock is ridiculous. When it’s seven o’clock, there are seven LEDs lit. Nice and easy to read. Sixty minute LEDs is silly, so here each minute LED stands for five minutes. Good enough.
What we really like about this clock is the build. It’s intended as educational for school kids, so it has to be simple to build and easy to personalize. Building the body out of Lego bricks fits the specs nicely. Transparent Lego bricks are used to give the white LEDs some color. That was too bright, so [Shrimping It] added paper cutouts from a hole punch as diffusers.
Clock builds are a great intro to electronics because they offer so many possibilities. Whether you want to go geary, use the clock as an excuse to try out fabrication techniques, or showcase a neat display technology, your imagination has a lot of room to wander. Show us yours?
Nice! It looks like a Minecraft Cylon.
If you want a clock that is simple to count up, why not the Set Theory Clock: https://en.wikipedia.org/wiki/Mengenlehreuhr http://www.3quarks.com/en/BerlinClock/
how about a urinary clock?
I have a unary clock, if the LED is light the time is now, here’s the circuit…
http://www.electroschematics.com/wp-content/uploads/2009/04/led-circuit.gif
Battery is backwards.
OMG, I reversed time!
Your take on binary options trading differs from most of the web blogs I review, I am satisfied.
Indeed.
