A Pi Robot Without A Hat
Daughter boards for microcontroller systems, whether they are shields, hats, feathers, capes, or whatever, are a convenient way to add sensors and controllers. Well, most of the time they are until challenges arise trying to stack multiple boards. Then you find the board you want to be mid-stack doesn’t have stackable headers, the top LCD board blocks the RF from a lower board, and extra headers are needed to provide clearance for the cabling to the servos, motors, and inputs. Then you find some boards try to use the pins for different purposes. Software gets into the act when support libraries want to use the same timer or other resources for different purposes. It can become a mess.
The alternative is to unstack the stack and use external boards. I took this approach in 2013 for a robotics competition. The computer on the robots was an ITX system which precluded using daughter boards, and USB ports were my interface of choice. I used a servo controller and two motor controllers from Pololu. They are still available and I’m using them on a rebuild, this time using the Raspberry Pi as the brain. USB isn’t the only option, though. A quick search found boards at Adafruit, Robotshop, and Sparkfun that use I2C.
This approach has challenges and benefits. A stack of daughter boards makes a neat package, where external boards makes a tangle of wires. Random sizes can make mounting a challenge. Providing power can also be a hassle because of the random placement of power pins. You can’t rely on USB power, especially from a Raspberry Pi whose USB is power limited.
On the other hand, external boards can offload processing from your main processor. Once a command is sent, these boards handle all the details including refresh requirements. They are likely to provide capabilities beyond the microcontroller software libraries since their processors are dedicated to the task.
I am using an 18-channel board from the Pololu Maestro Servo Controller family of boards that control from 6 to 24 servos using a single board. You might find the Adafruit 16 channel I2C board a useful alternative. For motor control I turned to the Pololu Simple Motor Controller family using one that will handle 18 amps. Others will handle from 7 to 25 amps. Or consider the Sparkfun Serial Controlled Motor Driver. Another source for USB controllers is Phidgets. I experimented with one of their spatial devices for the original robot. I should have used it to measure the tilt since one of my robots rolled over on a hill. Ooops!
Servo Control
The board currently installed on my robot is the Mini Maestro 18. The Maestro provides control over the servo speed, acceleration and movement limits. A home position can be set for startup or when errors occur. You can even do scripting or set movement sequences to play on command.
maestro familyOn the hardware side, the Maestro also allows channels to be used for digital input or output, and some channels for analog input. On some there is one channel for pulse width modulation output. An onboard regulator converts the servo power input to the voltage needed by the processor, simplifying part of the power distribution challenge.
My previous robot used the Maestro to control pan and tilt servos for camera positioning, a servo to lift samples from the ground, and a safety LED. Two analog inputs from current sensors on the motors helped avoid burnout during stalls, and four inputs from a simple RF key fob transmitter provided control. The latter came in handy for testing. I’d program a test sequence such as starting a 360° camera scan for landmarks or drive onto the starting platform and drop the sample. A button press on the key fob would initiate the activity. One button was always set up as an emergency halt to stop a rampaging robot. The rebuild is following this pattern with some additions.
Motor Controller
The two Simple Motor Controllers (SMC) each handled the three motors on either side of the Wild Thumper chassis. The SMC does more than just control the motor speed and direction. You can set acceleration, braking, and whether forward and reverse operate at the same or different speeds. The board monitors a number of error conditions for safety. These stop the motor and prohibit movement until cleared. Such blocking errors include lost communications, low input voltage, or drivers overheating.
smcAn additional capability I found extremely helpful is the ability to read signals from a radio control (RC) receiver. These signals can be used to control the motor and, with some cross wiring between two controllers, provide differential drive control. This is useful for driving the robot to a new location using an RC transmitter. I didn’t use the RC inputs directly. Instead I read the RC inputs and issued the control commands from my program. This let me monitor the speed in my program logs for correlation with the other logged data. I also used an input to command the robot into autonomous or RC control operations. There are also two analog inputs that can be used to directly control the motor and can be read through commands.
Serial Communications
USB ports were my choice for communications but there is also a TTL level serial port with the standard RX and TX pins. This port can be used by the Raspberry Pi, Arduino, or any other microcontroller that has a TTL serial port.
smc txinThe Maestro boards using USB appear as two serial ports. One is the command port that communications with the Maestro processor. The other is a TTL port. This port can serve as simply a USB to TTL serial port converter to allow communications with other boards, even from another vendor. Another use of the TTL port is to daisy chain Pololu boards. I could attach the SMC boards in this manner and save two USB ports for other devices. These boards support this by having a TXIN pin that ANDs the TX signal from the connected board with the TX on the board.
Both of these controllers support a few different communications protocols. I use the one Pololu created and is available on some of their other products. The command details are different between the boards, but the basic command structure is the same. They call it their binary protocol, and the basic format follows:
0xAA, <device address>, <command>, <optional data>, <crc>
All the fields are single bytes except for the data field which is frequently 2 bytes to transmit 16-bit data. The returned data is only one or two bytes with no additional formatting. Note they provide for detecting errors in the message by using a CRC (cyclical redundancy check). This is probably not critical over USB but a TTL line might receive noise from motors, servos, and other devices. A CRC error sets a bit in the error register that can be read if the command is critical.
I wrote my own code, C++ of course, for the PC and converted it just now to the Raspberry Pi. The main change is the different serial port code needed by Linux and Windows. Pololu now provides Arduino source for the protocol making it easy to use these boards with that family of controller boards.
Wrap Up
The chassis, Pi, and these boards are now installed on the Wild Thumper chassis along with a pan and tilt controlled by servos. A safety LED is on when power is applied and flashes when the robot is actively controlling the system. A LiPo battery powers all but the Pi because I need to configure a battery eliminator circuit to provide five volts. I’m powering it temporarily using a USB battery pack.
A test program, cross compiled from my desktop, moves the robot forward, pivots left than right, and then reverses. The pan / tilt moves and the LED flashes. I originally used a web camera for vision processing but will switch to the Pi camera since it is better. The Neato lidar discussed in a previous article will soon find a place onboard, along with an accelerometer to detect possible rollovers.
I’m sure I could have done this using Pi daughter boards despite the challenges I mentioned earlier. There are trade-offs to both approaches that need to be considered when working on a project. But there is one final advantage to the external boards: they have a lot of twinkly LEDs.
Product photos from Pololu.
10 thoughts on “A Pi Robot Without A Hat
  1. Personally I rarely find myself able to justify the premium for shields or whatever people want to call them. Unless the form factor for whatever reason is absolutely critical or they are dirt cheap. Neither seems to be a common case for me :P
    It’s always amazes me how much money you can typically save by sidestepping them whenever possible. Which is especially important if you are on a budget.
  2. This is the same approach that I am taking for the robot I am currently building. After looking at the requirements that I had, a “hat” just would not work the way that I wanted it too. As a central brain, I went with a Pi 3B, as it has built in wireless and Bluetooth, which freed up those USB ports and allows me to not use an additional USB Hub saving the project from even more clutter.
    1. Forgot to mention, the Pi does not run a RTOS, this means that attempting to directly access and use the GPIO for servos, steppers, or other peripherals can end up with some odd behavior when it’s primary OS (often linux) does its housekeeping. An example of this would be servos twitching when they should be holding position. It just makes sense to offload some of the more time critical operations to dedicated microcontrollers that can then interface with the central “brain”.
      1. It does not run an RTOS (by default) but you can offload driving servos and motor controllers to an on-chip peripheral, namely the DMA. The DMA can generate up 15 (I think) perfectly stable servo signals directly to the GPIO pins, plus there’s one hardware PWM channel on the Raspberry Pi (granted the kernel support for it is broken because of the clock being shared with I2S or something like that and the kernel claiming not to know that).
        The DMA can similarly be used for inputs such as reading an RC controller’s PWM or PPM signal (but you stilll only have ~15 channels for all of your inputs and outputs). Actually ArduPilot, arguably the leading aerial and terrestrial robot controller firmware, already does all of this in its HAL for the Raspberry Pi (but it can use “hats” too).
        I could never find a justification for a board like the Maestro or the servo and analog shields/hats. Even if you don’t want to do all of this on the main controller, a $1.50 *duino Pro Mini will happily take the load off your Linux board and you can communicate with it through your port of choice, I2C, serial, SPI. If you want neat cabling, use a proto board to make a completely passive hat to hold all of the servo 3-pin headers and the optional *duino.
        (Note: I2C communication is cool but it’s designed for *inter*chip* communication, not inter-module. The standard rates it for signal lines up to 10cm iirc)
        1. Good point about the DMA, it’s one of those black magic aspects of processors I’ve never looked at.
          For me reaching for a Maestro is a given because it’s COTS. There is always a tradeoff between use COTS and get it done versus let’s work on an equivalent device while the main project sits on hold. Besides, I’m a software guy, not a mechanical or hardware guy.
  3. Maestro controllers can be quite useful for dev speed, especially for those just starting out. (PC to USB serial control over a bunch of servos and some basic IO, no embedded programming)
    One warning; the output pulses to control the servos are staggered, not synchronised with one another. For example if you have fast servos and want three to move at once, there’s no way to do that – you’ll find that the servos move at very slightly different times.
    (If you need very precise timing, then RC servos are unlikely to work well – but one might often only discover the precision issue just before deadline!)
Leave a Reply to Rud MerriamCancel reply
