Etching Your Own Metal
It’s been said that with enough soap, one could blow up just about anything. A more modern interpretation of this thought is that with enough knowledge of chemistry, anything is possible. To that end, [Peter] has certainly been doing a good job of putting his knowledge to good use. He recently worked out a relatively inexpensive and easy way to etch metals using some chemistry skill and a little bit of electricity.
After preparing a set of stencils and cleaning the metal work surface, [Peter] sets his work piece in a salt solution. A metal bar is inserted in the other end of the bath, and both it and the work piece are connected to electrodes. The flow of electricity removes some metal from the exposed work surfaces, producing whatever patterns [Peter] wants.
One interesting thing that [Peter] found is that the voltage must stay under 6 volts. This is probably part of the reason it’s relatively easy to etch with even a wall wort. Above that, the iron work piece produces a different ion which can clog the work surface and create undesirable effects. Additionally, since his first experiments with this process he has upgraded the salt bath with magnetic stirrers. He also gets the best results in a very cold environment.
There are many other uses for etching metals, too. Creating your own printed circuit boards comes to mind, but there are plenty of other uses as well. What will you do with this technique?
25 thoughts on “Etching Your Own Metal
  1. Only issue with using stainless steel is it produces chromium in the electrolysis process so I guess it would here too.
    Perhaps you can combine with the rust removal process and colour it whilst processing parts at the same time.
    1. Both are relevant as you’re using electricity to force a reaction to go a certain direction. Voltage does matter but you’ve got considerable wiggle room (Check out a Pourbaix diagram for more info). Amperage’s precision requirement depends on surface area if you want to do things optimally and not boil away your electrolyte.
      1. I worked in this industry for over forty years and these processes were universally worked by amperage. Mostly because large working solutions tend to change over time, temperature and the volume of work passing through them during a shift. The only thing that one could use to keep results within spec was to work with current density. Voltages, as long as they were higher than the minimum to get the reaction going in the right direction, was never a real concern simply because they would vary widely over time.
        Having said that, there are some processes like anodizing and alloy plating where voltage is a significant factor, but on the etch and basic plating lines, everyone works with amperage.
  2. Really? He.. “Worked it out”. This has been done for well over a century with various chemicals for different materials and final finishes etc. So very not worthy of a post on here. Especially since there are also 34,527,164,839 other examples of this on the web already.
    Please stop regurgitating the same ole stuff. It causes stagnation.
      1. Not at all. It’s not the solutions that you use, it’s how you handle the wastes that are the issue. Some modern formulations claim to be better in that regard, but often that’s not always the case. There is no quick fix to replace good shop practice.
      2. Yea, nothing. In fact, simple sodium chloride solution is all that is required for most metals. It may not be the best solution , or give the finish you want , but it will do just fine.
  3. This article is somewhat confusing. It mentions an iron work piece, but the linked gallery pertains to X5CrNi18-10 (stainless steel). There’s a reference to magnetic stirrers, but I can’t find that in any of the linked content. Was the article based on information from the tip line rather than the content? Is something missing?
    I’ve tried etching stainless steel in a saltwater electrolyte, using 12V at several amps, with very different results. There was no relief, but the etched surface had a crystalline appearance as if certain elements of the alloy were removed along grain boundaries. Very strange. Since then I’ve just used good ol’ ferric chloride, which performs as expected.
  4. I’m a high school science teacher and I just did something like this last week with the student-led chemistry club. We used 9V batteries, alligator leads, and Q-tips dipped in a salt-vinegar solution. Some masked designs off with masking tape and hobby knives, while some painted freehand with the Q-tip. Very fun!
Leave a Reply to TheBestJohnCancel reply
