Reprogramming Bluetooth Headphones For Great Justice
Like a lot of mass-produced consumer goods, it turns out that the internal workings of Bluetooth headphones are the same across a lot of different brands. One common Bluetooth module is the CSR8645, which [lorf] realized was fairly common and (more importantly) fairly easy to modify. [lorf] was able to put together a toolkit to reprogram this Bluetooth module in almost all of these headphones.
This tip comes to us from [Tigox] who has already made good use of [lorf]’s software. Using the toolkit, he was able to reprogram his own Bluetooth headphones over a USB link to his computer. After downloading and running [lorf]’s program, he was able to modify the name of the device and, more importantly, was able to adjust the behavior of the microphone’s gain which allowed him to have a much more pleasant user experience.
Additionally, the new toolkit makes it possible to flash custom ROMs to CSR Bluetooth modules. This opens up all kinds of possibilities, including the potential to use a set of inexpensive headphones for purposes other than listening to music. The button presses and microphones can be re-purposed for virtually any task imaginable. Of course, you may be able to find cheaper Bluetooth devices to repurpose, but if you just need to adjust your headphones’ settings then this hack will be more useful.
[Featured and Thumbnail Image Source by JLab Audio LLC – jlabaudio.com, CC BY-SA 4.0]
29 thoughts on “Reprogramming Bluetooth Headphones For Great Justice
    1. Yes it’s locked. From what I recall you need to set a PSKEY (i.e. flash-stored variable, which you can edit with PSTOOL) to be equal to a hash based on the per-chip unique ID; so, not easily hacked. This is from memory, could be wrong.
    2. Really? The better codec and the hardware capable of using it is built in and locked somehow? What use does this have? Is this just a greedy licensing issue? Then this should be hacked better yesterday than today.
      1. Having that codec generally at least doubles the price of BT headsets/headphones.
        Yest it’s money grabbing through licensing, that’s how the capitalistic system works. And also why we appreciate the Chinese so much on HaD ;)
  1. If you want to play along at home and you live in the UK, then a trip to PoundWorld will get you a “CSR BC6130 dev board” for £1 in the form of a “Native Union Pop Bluetooth Phone” which by pure co-incidence we were discussing recently here -> http://stm32duino.com/viewtopic.php?f=45&t=1746#p22984
    Pictures of teardown here. -> https://photos.google.com/share/AF1QipO3KoKFDsX0yN2ZjxKNpVAgAohGj4YZZ6rtU9YF7xD_YhYvRdtuXUf60Z-FzourKQ?key=UGpwbzFIdFpoYVJYZnlHYTFhYXFIQzRPQXJLcWFn
    1. Just going to point out that an establishment being called PoundWorld would have a completely different connotation on this side of the pond…
  2. So I’ve bought a pair of really cheap chinese built bluetooth 4.1 headphones. When you action a command, a Chinese woman’s voice confirms your command. For example, when the bluetooth headphones connect to a device, you hear “connected”.
    Problem is, the voice is so loud, and there’s no way of changing the volume of it (even if you turn the volume down on the headphones). I’ve got used to switching on the headphones and connecting them to a device THEN putting the headphones in my ears to avoid the shouting, but when the battery is low, it says “battery low” and it makes me jump every single time + hurts my ears!
    Anyway, case and point – as a complete newbie, will this toolkit be self explanatory enough to help me in hacking my headphones to turn down/mute the voice?
    1. Buy an inline volume control. I have to hack it to shorten it, but with IEM’s even at level 1 is too loud, so the analog control is handy, and a customized length is good too.
  3. Secupix bluetooth headphone bought online but are not supported by ps4 .Only high price products are supported it seems . Could i change the software/firmware to match or replicate those high end devices
  4. Any idea if this would work with a pair of MDR 1000X? As i would like to be able to reprogram the buttons, also change the following: Speech prompts, “Power On” & “Low Battery”
    I have a feeling that is kept in an xml file. Add more values so it would read out a battery % as opposed to “Battery High, Medium or Low.” Any help with getting this to work would be greatly appreciated. Also using this as a headset for the PS4 would be awesome too.
  5. abit offtopic
    Can you hack/clone the Bluetooth signal from a PS4 controller
    And flash it to a bluetooth keyboard/mouse combo (only assign needed keys on the keyboard)
    Is this impossible or doable in some way? (The low tech version would be to just open the controller to the keyboard/mouse, but can you convent the analog stick to the optic sensor? The analog will always return to center)
    This way the console will not see a keyboard/mouse is connected only a controller (:
    Anyone know if it’s possible? (:
  6. Hi, I need help, I have some Sennheiser HD 4.40 headphones that reproduce the sound that the microphone picks up during the phone call, how can I change this? Thanks
  7. How difficult would it be to repurpose an old bluetooth headset to control an led strip with my phone? Thanks from a novice..
  8. I have antaudio wave sports 540
    I want to use google assistant with my neckband
    And increase it’s mic quality
    Can anyone help me
  9. Smartphones and notebooks with Bluetooth capabilities can attach to several devices at the same time. The new Bluetooth five standards enable up to seven devices to link to a primary computer in active mode at the same time. Some Bluetooth accessories can use the same Bluetooth profile or features, resulting in a dispute.
Leave a Reply to ItsThatIdiotAgainCancel reply
