Rolling Around A 4th Axis
[Perry] was interested in adding a 4th axis to his CNC machine, but not very excited at the prospect of spending hundreds of dollars on the parts and electronics to make it work. There is a very clever and very inexpensive way to add a 4th axis to a CNC machine, though, and after a bit of fabrication, he was able to add a ‘rolling’ 4th axis to his machine.
[Bob]’s ‘rolling’ 4th axis.
The idea for this build comes from [Bob] over on the CNC Shark forums. Instead of adding a motor to rotate a work piece around, [Bob]’s build simply mounts it between two jaws, and rolls everything around against the bed of the CNC router. Don’t have a clue what that means? Check out the picture to the right, and you’ll see brilliance built in Delrin and HDPE.  By mounting two rack gears to the bed and two geared jaws to the carriage of the machine, moving the router in the Y axis also rotates the 4th axis. This is far, far too clever; it doesn’t require any additional electronics and the only software tweaks are a bit of G-code hacking.
[Perry] took one look at [Bob]’s project and decided this would be the perfect build to get him a 4th axis. The parts for this build were fabricated out of black HDPE, with the only real change to the design being a ‘variable length’ 4th axis. Instead of two rack gears mounted to the bed of the machine, [Perry]’s build only uses one rack, with the other end simply rolling on the bed.
There are a lot of clever inventions that don’t work, so what’s the verdict with this CNC hack? It actually looks pretty good. [Perry] was able to turn some square stock into round stock, and able to engrave a spiral around a cylinder. You can check out those videos below.
23 thoughts on “Rolling Around A 4th Axis
  1. My initial thought was that it looks like an overengineered lathe but on second thought I realized you could make some asymmetric designs. I like it but it needs to be higher off the bed for thicker materials. That said, there are some really cool five and six axis CNC machines that are much better and I’ll never be able to afford. ;)
    1. Look at the link and there’s a video of him making a dodecohedron with it, something you absolutely couldn’t do on a lathe :)
    1. Exactly, it’s a different third axis.
      Just looking at the image I thought the cleverness was that the 4th axis was independent from the Y axis and that the tool could somehow push the roller around to control the 4th axis. With some smarts this could actually be doable with about the same complexity, would just need a way to lock the roller angle when it’s not intentionally being rolled.
  2. As pointed out, this is really just a 3-axis machine with one being rotary instead of linear. A true 4-axis machine can do things like bore holes off of the centerline of the workpiece; this one cannot.
    Still, it’s a clever way of getting rotary carving on a limited budget if you don’t need real 4th-axis capability.
  3. I’m wondering if you could use the tool end to press on a mechanism which rotates the work piece just a little. Then move your tool over the work piece using full 3 linear axis like normal. Then rinse and repeat. This would give you a proper 4th axis usong only the 3 motors. Locking type gears would help.. eg a worm gear.
  4. Author mentions in this article that moving the Y axis causes the workpiece to rotate, surely we all know that the Y-axis from math is vertical- so therefore this statement is wrong. It should say the X-axis or z-axis (depending join interpretation.
    1. In CNC machines and other machinery such as industrial robots, Z is almost universally the vertical axis. X and Y fall on the horizontal plane, like drawing on paper in math class.
  5. You could make a small version of this, and sell it for decorating Easter eggs. Make a small fortune.
    You could call it “Egg Bot”.
    Oh wait…
  6. This is really cool. I hope you don’t mind if I adapt this to my little 3 axis CNC/Laser engraver that I just bought to do engraving on the turned pens I make. It only has a 6 x 9 inch work area so its quite small compared to yours. I was going to draw it up first but I’m more of a hands on type of guy so I just jumped in and started designing each piece as I go. I’ll let you know how it goes.
Leave a Reply to ClaraCancel reply
