There’s a lot going on our virtual spaces, and anyone with a smart phone can attest to this fact. There are pop-up notifications for everything you can imagine, and sometimes it’s possible for the one really important notification to get lost in a sea of minutiae. To really make sure you don’t miss that one important notification, you can offload that task to your own personal dinosaur.
The 3D-printed dinosaur has a rack-and-pinion gear set that allows it to extend upwards when commanded. It also has a set of LEDs for eyes that turn on when it pops up. The two servos and LEDs are controlled by a small Arduino in the base of the dinosaur. This Arduino can be programmed to activate the dinosaur whenver you like, for an email from a specific person, a reply to a comment on Reddit, or an incoming phone call to name a few examples. Be sure to check out the video below the break.
With this dinosaur on your desk, it’s not likely you’ll miss its activation. If you’d like something that has the same function but with less movement and more lights, there’s also a notification 3D cube made out of LEDs that’s sure to catch your eye as well.
Thanks, HaD, for including simple, easy hacks as well as the astonishingly complicated and difficult ones. I may not be able to decap a 65C02 or produce a one square inch oscilloscope, but I can make this just with the parts I already have on hand. Bravo!
