Hydrogen Powered Nerf Blaster Is Dangerously Awesome
Nerf blasters have been around for decades now, exciting children and concerning parents alike. Most are powered by springs or compressed air, and are the ideal holiday toy for putting delicate family heirlooms at risk. Not content to settle for the usual foam-flinging sidearm, [Peter Sripol] decided to take things up a notch.
The build starts with a MEGA CYCLONESHOCK blaster, which uses the larger red NERF darts as ammunition. Water tanks are rigged to the outside, fitted with stainless steel electrodes. The original spring & plunger firing  assembly is then removed, to make room for a firing chamber made out of copper pipe. A small taser-like device is used as an igniter. When the charging switch is pressed, current is passed through the electrodes in the water, which splits the water into hydrogen and oxygen gas. This is then passed to the firing chamber, where it can be ignited by the taser module, activated by the trigger.
Despite some issues with the blaster occasionally destroying darts due to what appears to be overpressure, it is capable of higher shot velocities than the stock blaster. For all its complexity, performance is somewhat hit and miss, but the cool factor of a handheld hydrogen bubbler is hard to ignore. [Peter] does note however that the combination of explosive gases and dangerous catalyst chemicals make this one build that’s probably best left to adults.
If this NERF hack isn’t dangerous enough, you might prefer these Taser darts instead. Video after the break.
[Thanks to Baldpower for the tip!]
10 thoughts on “Hydrogen Powered Nerf Blaster Is Dangerously Awesome
  1. Thats what I like to see :D
    That realy is dangerously awesome love it ….
    Can’t wait till my boys are big enough to play with shit like that ….
  2. Hydrogen actually likes a small excess of oxygen to get a real kick. So burning a tiny amount of that H2 with oxygen from the outside air might give even more oomph. The choice of copper for the firing chamber is not one I’d make though. Yes it’s nice and easy to get, it’s however not the strongest of materials. The only pro I can think of is that it might not cause as much schrapnel if it was to explode as a more brittle steel.
    1. This isn’t 10:1 compression in a piston engine. I can’t imagine how you would get enough H2 in that little chamber at one atmosphere to do anything other than the “pop” he was getting. Hitting a pistol primer with a hammer (protect against tiny shrapnel) is deafening in comparison. You may recall all the potato canons made from PVC…..
  3. They should use silver 999 which is the best conductor than their inox steel plates for the electrolyte that will result in more gas for the same amount of electricity.
    It will load and fire faster :)
Leave a Reply to dr.rockzoCancel reply
