We’re certainly no strangers to unique timepieces around these parts. For whatever reason, hackers are obsessed with finding new and interesting ways of displaying the time. Not that we’re complaining, of course. We’re just as excited to see the things as they are to build them. With the assumption that you’re just as enamored with these oddball chronometers as we are, we present to you this fantastic digital tachometer clock created by [mrbigbusiness].
The multi-function digital gauge itself is an aftermarket unit which [mrbigbusiness] says you can get online for as little as $20 from some sites. All he needed to do was figure out how to get his Arduino to talk to it, and come up with some interesting way to hold it at an appropriate viewing angle. The mass of wires coming out of the back of the gauge might look intimidating, but thanks to his well documented code it shouldn’t be too hard to follow in his footsteps if you were so inclined.
Hours are represented by the analog portion of the gauge, and the minutes shown digitally were the speed would normally be displayed. This allows for a very cool blending of the classic look of an analog clock with the accuracy of digital. He’s even got it set up so the fuel indicator will fill up as the current minute progresses. The code also explains how to use things like the gear and high beam indicators, so there’s a lot of room for customization and interesting data visualizations. For instance, it would be easy to scrap the whole clock idea and use this gauge as a system monitor with some modifications to the code [mrbigbusiness] has provided.
The gauge is mounted to a small project box with some 3D printed brackets and bits of metal rod, complete with a small section of flexible loom to cover up all the wires. Overall it looks very slick and futuristic without abandoning its obvious automotive roots. Inside the base [mrbigbusiness] has an Arduino Nano, a DS1307 RTC connected via I2C, a voltage regulator, and a push button to set the time. It’s a perfectly reasonable layout, though we wonder if it couldn’t be simplified by using an ESP8266 and pulling the time down with NTP.
We’ve seen gauges turned into a timepiece before, but we have to admit that this is probably the most practical realization we’ve seen of the idea yet. Of course if you want to outfit the garage with something a bit more authentic, you can always repurpose a Porsche brake rotor.
What digital gauge has he used ?
heres some pictures of it
https://imgur.com/gallery/uxv14BN
Where did these photos come from? As far as I can tell you look only to a GitHub repository with three files and no documentation except as comments in Arduino sketches.
As it’s Imgur, I’d guess the project was described on Reddit. Why had didn’t give us the full info, I don’t know…
Yup just search for u/mrbigbusiness on Reddit and you find this
https://www.reddit.com/r/arduino/comments/a371um/used_an_arduino_to_turn_a_speedometer_into_a_clock/?utm_source=reddit-android
This looks like the one
https://www.amazon.com/Samdo-Universal-Speedometer-Tachometer-Motorcycle/dp/B01LXWKGGX/ref=sr_1_132_sspa?ie=UTF8&qid=1547849662&sr=8-132-spons&keywords=Tachometer&psc=1
Yeah he might say you can get it for $20, but the cheapest I’ve found is $40.
Not checking the right sites then.
https://m.banggood.com/12000-RMP-LCD-Digital-Speedometer-Odometer-Motorcycle-1-4-Cylinders-p-972677.html?rmmds=search
https://m.aliexpress.com/item/32733561108.html?pid=808_0000_0101&spm=a2g0n.search-amp.list.32733561108&aff_trace_key=&aff_platform=msite&m_page_id=2406amp-E3wmMOwoXo5fecKM4T9oSA1547906481000
Put an alarm on it with a choke lever for the snooze function? I dunno.
https://www.aliexpress.com/item/Hot-hothot-LCD-Digital-Tachometer-Speedometer-Odometer-Motorcycle-Motorbike-12000RPM-se16/32733561108.html?spm=2114.search0104.3.92.78b4b2a1TTxG8C&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_10547_319_317_10548_10696_453_10084_454_10083_433_10618_431_10307_537_536_5736111_5736011_10059_10884_10887_100031_321_322_10103,searchweb201603_51,ppcSwitch_0&algo_expid=4d8cb6c1-70b8-4615-b518-befbbb99ab8a-13&algo_pvid=4d8cb6c1-70b8-4615-b518-befbbb99ab8a&transAbTest=ae803_5
