This Light-Up Sorter Is A Bright Idea
Sorting out a mountain of screws and other workbench detritus by hand is a task that only appeals to a select few of us. [AdrienR] is not one of those people. He believes the job is better suited to a robot, so he built an intelligent and good-looking machine that does just that.
[Adrien]’s sorting bot is capable of organizing a hodgepodge of parts quickly and effectively. He simply scatters the parts on the light box work surface, illuminates it, and takes a picture with a downward-facing web cam. An algorithm studies the parts and their positions using OpenCV image processing, and sends the triangulation back to the arm so it can pick and place the parts into laser cut boxes using a home brew electromagnet.
[Adrien] calls this a work in progress. He plans to control it with a Raspberry Pi so it can be a standalone unit, and will probably move the parts boxes to the outside curve. Drop yourself past the break to see it sort.
If delta robots are more your sort, this one has balls. Colored balls.
14 thoughts on “This Light-Up Sorter Is A Bright Idea
    1. INOX is a BRAND of stainless steel. It is inappropriate to call all stainless steel Inox, regardless of where you are from. Stainless is more appropriate, however it can even be inappropriate in some cases.
  1. That was the best demo video they had? It missed! If you HAVE to push out a demo video before something is working well, keep the camera rolling until it doesn’t miss!
    1. it also looks like it putting all the parts into the same box, not really sorting is it? But other then that the fact that it seems to find the component is a huge accomplishment. Now I hope that there is a demagnetizer in that build also, because sometimes it’s really annoying when parts seem to cling together because they are magnetized. Promissing project, fun to see it work. hope to hear/see more of it.
  2. Its cool buut washers go with washers not nutz. Left three pieces. Now add conveyor belt and ability to pick up /distinguish non ferrous. Thread size and length discrimination needed. Round heres we gots SAE and metric. Also would be nice if could read tape reel fallouts and test them while sorting. Would be nice if end effector could do some axis instead of whole arm up/down. Fix it. Fix it.
Leave a Reply to Mike ChurchillCancel reply
