The World’s Smallest Vacuum In An Altoids Tin
There’s been a lot of Altoids tin hacks over the years, but a vacuum cleaner in a tin is something new. In [Toby Bateson]’s first project on Hackaday, he used simple household items to create a functioning vacuum cleaner to use for sucking crumbs out of your keyboard or paper punch holes off your desk.
The vacuum features a retractable suction tube, a low-profile switch, and a bagless waste collection system (the waste is stored and discarded out from the tin itself). A brushed motor and impeller provide the airflow. A scrap of a beer can mounted on the shaft is used for an impeller blade, and two bolts with a thin metal sheet between them are made into a switch (the instructions recommend you finish your drink before using the scrap metal). A sponge is used for filtering the dirt from the motor while a hole is cut out of the top of the tin to provide airflow.
[Bateson] is looking to put his name in the world record book for the world’s smallest vacuum tube, as he recently created an even smaller vacuum in a 1cc tube.
“Oh dear, I’ve spilled something on my desk, whatever am I going to do? Luckily, I have my vacuum cleaner in an Altoids tin…”
10 thoughts on “The World’s Smallest Vacuum In An Altoids Tin
          1. “human”, I never looked at it that way. I always idolized them to be perfect in any way.
            But, honestly, you are completely right without a doubt.
            Things like this can and will happen. But for some reason these things SEEM to happen much more often then they did in the past. But there is a benefit to this, as it allows us to see the different approach to the same article by different editors. So, as you can see, there is a bright side to everything.
  1. Can actually be a really handy bench tool for cleaning precision cleaning for up wire snips etc without also sucking up nearby components as well. A 3d printed version would be pretty cool
Leave a Reply to LilyCancel reply
