Around these parts, seeing a classic laptop or desktop computer get revived with the Raspberry Pi is fairly common. While we’re not ones to turn down a well-executed Pi infusion, we know they can be controversial at times. There’s an impression that such projects are low-effort, and that the combination of old and new tech gains little in the way of usability due to the usability quirks of the Pi itself.
But we think even the most critical in the audience will agree that this build by [Tylinol], which sees the internals of a circa 1993 PowerBook 165c get replaced with that of a 2014 Mac Mini, is something else entirely. For one thing, there’s no question that packing a modern (relatively) desktop computer motherboard into a laptop’s body takes a lot more planning and effort than hot gluing the comparatively tiny Pi into the same space. Plus as an added bonus, anyone who counts themselves among the Cult of Mac will be happy to see the vintage machine retain its Cupertino pedigree.
So how do you get a Mac Mini inside of a PowerBook? Very carefully. As explained by [Tylinol], the inside of the PowerBook’s case was coated in graphite and conductive enough to be a problem. So after the original hardware was removed, a layer of tape was added to insulate it; though we imagine a suitably thick spray-on coating could be used as well if you don’t have that kind of patience.
Once the case was gutted and insulated, [Tylinol] added new stand-offs to mount the Mac Mini motherboard and hard drive. For anyone wondering, the 2014 model was used because the shape of the board almost perfectly fits around the trackball PCB. A board from a newer Mac could be used, but it would likely mean using an external mouse.
Which would have been a problem for [Tylinol], because one of the main goals of this build was to get the original input working. That meant adapting the Apple Desktop Bus (ADB) devices to USB, which turns out to be something of a Dark Art. But with the help of some contemporary information about the long-forgotten protocol and a Teensy 3.5, both devices are now picked up as standard USB HID.
But of course, that’s just scratching the surface. [Tylinol] also had to figure out how to swap the original display out for a modern panel, and then get the whole thing running on internal battery power. Even if you’re not particularly interested in retro Apple hardware, this is really a phenomenal build that deserves a thorough read-through.
For those of you who don’t mind getting a Pi in a PowerBook, we recently saw a recreation of Lord Nikon’s laptop from Hackers that went that route.
I keep my Powerbook, same model, around in case I might have a need for a Mac that old. It beats keeping a Mac Classic around. Plus, I perhaps might need a terminal.
That might be the better route, put the Pi in a small box and use the Powerbook as a terminal over a serial port. Then at least the primitive screen has an explanation.
Steve Jobs would be proud, or mad, or indifferent but I think this is pretty awesome.
Steve Jobs wouldn’t care either way. Neither were produced under his rule.
This is… different. Unexpected. I think I like it.
Respect.
It’s not a graphite coating. It’s coated with a metal alloy that has a melting temperature low enough it could be applied to the plastic without melting it. Apple used it on most of their beige desktops and early laptops. Cost was the driving factor to develop the process. It had to be easier/faster to apply than the sprayed on coating inside the old apple ][ and less costly and time consuming than vaporizing aluminum in a vacuum chamber.
ADB to USB adapters were made for a while years ago after the original iMac and the Mac desktop that replaced the Beige G3’s were introduced. Today bigmessowires sells a new ADB to USB adapter called the Wombat, but it looks bulkier than the old single port Griffin iMate. For the keyboard there are programmable switch matrix to USB adapters.
Now let’s see the reaction of the technical staff at the “Genius” bar…
That would be funny
So cool! I have old Macs in my garage (and Apple //e). I’ll have to see if there is one of my 90’s era power books out there too!
