A Tool For Testing CANopen Networks
If you find yourself working with CANopen CC networks, you might find yourself in need of a tool for monitoring what’s happening on the wire. [Michael Fitzmayer] whipped up a piece of software to fulfil just that role.
CANopenTerm might be named after the CANopen standard, but it’s really a terminal-driven tool for working with CAN buses in general. The software is built for real-time use, allowing sniffing raw frames on the wire, tracing, and probing of nodes, all from within the console. It’s also possible to add scripting via Lua or Python for more advanced work, as well as do protocol-aware inspection if that’s relevant to your use case. The key idea of the software is to be fast and scriptable to suit a given need, rather than bogging everything down with a heavy GUI interface that’s slower to work with.
If you aren’t afraid of getting into the nitty gritty with CAN and like lightweight text-based interfaces, this might be the tool for you. We’ve also explored some other CAN visualization tools lately, as well. Ultimately, there is a lot of machinery out there running on some variant of CAN or other, so it pays to know how to work with it. If you’ve got your own projects cooking up in this space, don’t hesitate to let us know on the tipsline!
6 thoughts on “A Tool For Testing CANopen Networks”
    1. Thanks for the suggestion; I appreciate it.
      I actually recently resolved a few issues in the Ixxat back-end, which you can see here:
      https://github.com/CANopenTerm/CANvenient/issues/3
      These fixes will be included in the next release. I’m planning to move to a quarterly release cycle going forward. However, you can always download the most recent CANvenient.dll from GitHub and replace it manually.
      There’s also already a list of supported vendors available, and I now intend to expand it into a more comprehensive overview soon:
      https://canopenterm.de/canvenient?id=supported-back-ends
  1. As a wrench, the more I learn about this, the less I know about what is actually going on with the poorly written software/cobbled networks I wrestle with every day. I appreciate the help. (Autel MaxiFlash VCMI shows up as a wired ethernet connection in Ubuntu BTW)
  2. So someone’s never heard of Busmaster? CSS electronics? the challenge here isn’t decoding CAN, its getting the hardware between the canbus and the computer cheap. Theres PEAK and KVASER for the rich people, and arduio with an amazon tramseiver board for those with patience.
