Edge-Lit 7-Segments Clock The New Normal
People keep saying that time has lost all meaning now, but we’re still over here divvying up the days with hacks. Most of the hacks you see here are open source. But if you want something even more transparent to meter out the meaninglessness, we invite you to make one of these clearly awesome see-through clocks, which happens to be both.
A word of warning though — according to [GeekMomProjects], this is an incredibly fiddly build with tight tolerances everywhere that acrylic meets acrylic or an LED strip. We can see how it might be like forcing fragile puzzle pieces together. Since the whole thing is crystal clear acrylic, light is going to go everywhere.
[GeekMomProjects] cleverly blocked the escaping light by painstakingly applying non-conductive adhesive foil to the edges of all the smaller pieces. In spite of all that work, we think it would be worth it to have such a fantastic timepiece glowing away the hours somewhere in the house.
Electronically speaking, this beauty is pretty simple. The lights run off of an ItsyBitsy M4 Express, and the time is separately fetched with an ESP8266. [GeekMomProjects] had so much fun that she made one with seconds and one without. Check out their RGB dance routine after the break.
If you prefer your blinky 7-segment clocks a bit more utilitarian, here’s a clock made of shelves.
6 thoughts on “Edge-Lit 7-Segments Clock The New Normal
    1. Some fibercoupled serial RGB LEDs on the market yet?
      So far, i’ve only seen at most a single RGB LED coupled (very inefficiently) into a bundle of glass fibres.
      I’d think you could hide away all the LEDs in the base and just use glass fibre to guide the light into the different segments, then use some scatter lens, or something like that, to spread the light across the segment surface.
      The 10mm thickness restriction should not be a huge issue. Either you get the light to the segments from the side, or you could probably even try to set a tiny 45° mirror on the end of each fibre to “bend” the light around very tight corners, allowing you to get the fibre path directly behind the segment display and allowing for a tighter grouping of individual segment displays…
Leave a Reply to MisterTowelCancel reply
