Is It A Toy? A Prototype? It’s A Hack!
Some of the coolest hacks do a lot with a little. I was just re-watching a video from [Homo Faciens], who after building a surprisingly capable CNC machine out of junk-bin parts and a ton of ingenuity, was accidentally challenged by Hackaday’s own [Dan Maloney] to take it a step further. [Dan] was only joking when he asked “Can anyone build a CNC machine out of cardboard and paperclips?”, but then [Homo Faciens] replied: cardboard and paperclip CNC plotter. Bam!
My favorite part of the cardboard project is not just the clever “encoder wheel” made of a bolt dipped in epoxy, with enough scraped off that it contacts a paperclip once per rotation. Nor was it the fairly sophisticated adjustable slides and ways that he built to mimic the functionality of the real deal. Nope.
My favorite part of this project is [Norbert] explaining that the machine has backlash here, and it’s got play there, due to frame flex. It is a positive feature of the machine. The same flaws that a full-metal machine would have are all present here, but due to the cheesy construction materials, you can see them with the naked eye instead of requiring a dial indicator. Because it wiggles visible tenths of an inch where a professional mill would wiggle invisible thousandths, that helps you build up intuition for the system.
This device isn’t a “prototype” because there’s no way [Norbert] intends it for serious use. But it surely isn’t just a “toy” either. “Instructional model” makes it sound like a teaching aid, created by a know-it-all master, intended to be consumed by students. If anything, there’s a real sense of exploration, improvisation, and straight-up hacking in this project. I’m sure [Norbert] learned as much from the challenge as we did from watching him tackle it. And it also captures the essence of hacking: doing something unexpected with tech.
Surprise us!
This article is part of the Hackaday.com newsletter, delivered every seven days for each of the last 200+ weeks. It also includes our favorite articles from the last seven days that you can see on the web version of the newsletter.
Want this type of article to hit your inbox every Friday morning? You should sign up!
2 thoughts on “Is It A Toy? A Prototype? It’s A Hack!
  1. “where a professional mill would wiggle invisible thousandths”
    A worn out manual Bridgeport mill can wiggle over 1/8″ at the ends of the table with worn out table gibs, and still be worked around (albeit poorly), when your boss won’t pay to fix it.
    Normally though, any 20 year old or newer professional CNC machine, lathe or mill, should have “wiggle” in 0.0001″ or less range, not “0.001” so you’re literally about an order of magnitude off on that.
    That said, just trying to give a better idea of exactly how precise the normal equipment is.
    Anyone that takes a challenge to make a working whatevever out of only cardboard and paperclips and achieves that is my kinda guy, even if it’s not as precise, it’s quite ingenuitive.
    1. Wow. 0.0001″. Or 2.54 micrometers, if you’re into units that stick to decimals. About the width of a single bacterium. That’s amazing.
Leave a Reply to qwertCancel reply
