Mix It Up With A Multi-Volume Controller
What’s the use of waiting around for something to break in order to hack into something else? As long as it’s just sitting around not being used, who cares? [OmniSaiRen] had a  Behringer MIDI controller just taking up space. Instead of selling it, they decided to build it into something they would definitely use — a multi-volume controller with mute keys and other useful macros.
After gutting the case, [OmniSaiRen] gave it a couple coats of glossy white paint that looks really nice with the black keycaps and knobs. The plan was to use the original encoders, but [OmniSaiRen] replaced them with potentiometers when they couldn’t get the encoders working with the Arduino Nano. We are sad to report that Cherry Blues only made it to the build because they have all black housings and were also lying around taking up space, but maybe [OmniSaiRen] will grow to love them.
If you’re tired of all the mousing and clicking it takes to turn down this or that volume, you need to build one of these things. It runs on deej, an open source volume mixer that works with Linux and Windows, so what are you waiting for? If you only want a single hardware volume knob, you can’t go wrong dialing it in rotary style.
Via r/duino
3 thoughts on “Mix It Up With A Multi-Volume Controller
  1. So, there isn’t any software out there that would have allowed you to map the MIDI controls to what ever function you would want on your computer?
    Just seems a bit wierd to me to gut the device completely, just for the plastic case…
  2. Not impressed. Destroying something that worked, and could be useful to someone, for its case. A similar case or panel could be made with MDF or aluminium. The buttons look terrible and the knobs don’t match.
    Not a hack because it doesn’t look like a hack. If it did, it would be cool. Instead it looks like wanton destruction by someone who doesn’t really seem to care about the result anyway.
Leave a Reply to Andrew Cancel reply
