If you think you’re having a bad day at work, pity the poor sysadmin at Victoria University of Wellington in Australia New Zealand, who accidentally nuked the desktops of pretty much everyone at the university. This apparently happened last week and impacted everyone connected to the university network with a Windows machine, which had any files stored on their desktops deleted and also appears to have reset user profiles to the default state. This caused no end of consternation, especially among those who use their desktop folder to organize work in progress; we’d imagine more than one student at VUW is hating life right now for not storing work on a backed-up network drive. The problem seems to have started with an attempt to clean up files and profiles left behind by former students; how that escalated to nuking files on the desktop will require some ‘splaining.
Speaking of mea culpas, there was quite a dustup this week in the Cricut community. It started when the maker of CNC cutting machines announced its intention to limit uploads to their online design software unless the user signs up for a $10 a month account. After getting an earful from the users, the CEO of the company announced that these changes would be delayed until the end of 2021. That decision still didn’t sit well with the community, which includes a fair number of users designing PCBs, and two days later, the CEO announced that they were throwing in the towel on the whole plan, and that everything was going back to status quo ante. Story over? We’ll see — it seems like Cricut has tipped its hand here that they’re looking to extract more money from the users, and the need for that likely hasn’t gone away just because they relented. As Elliot Williams pointed out when we discussed the whole debacle, it’s easy to see how Cricut could start adding new features to the paid version of their software, basically abandoning the free user base. We’ll have to see how the obviously vociferous community responds to something like that.
Much interesting news from Mars this week, where the Perseverance rover is getting used to its new home and getting itself ready to roll. Late last week, Perseverance successfully dropped the “belly pan” that was covering the sensitive instruments under the rover, including the Adaptive Sample Caching system that will seal up Martian core samples and drop them out onto the surface for later pickup. This seemingly simple task was a critical one; had the pan not cleanly separated, the mission could have been severely impacted. Perseverance also did a little test drive this week, and recorded what it sounds like to drive on Mars. The audio clip is 16 minutes long, and the noises coming from the billion-dollar rover are just awful at times. We hear clunks and clanks and squeals galore, and while we’re sure they all have a good explanation and will provide valuable engineering data, they sound somewhat alarming to us.
But not so alarming as the sounds that must have come from a Jeep that suffered a bad tow job recently. The cringe-making story starts with a brand-new Jeep being towed on its wheels behind a motorhome, which allows the RV owners to park their rig and still have something to drive around in while they camp. The towed vehicle, or “pusher”, is normally equipped with a manual transmission, as towing with the wheels on the ground for extended distances is easier with them. Unfortunately, the Jeep’s owner set up the shift levers wrong and left the transmission in first gear, with the transfer case in low range. The linked article estimates the gearing ratios meant that the poor Jeep’s engine was being spun at something like 54,000 RPM; chances are good the engine exploded long before that point. The damage shown in the video accompanying the article is just brutal — the oil pan and bell housing are gone, the bottom of the crankcase is blown out, and at least two pistons and their share of the crankshaft are missing in action. We feel sorry for the owner, but really wish the Jeep had had a belly cam like the one on Perseverance.
The victoria University of Wellington is in Wellington… Which is the capital city of New Zealand… Which, contrary to popular belief, is not an Australian colony.
Many apologies for this oversight. Thanks for the correction. This is updated now.
Being Canadian I feel your pain.
Wellington is in New Zealand. Just sayin’.
s/Australia/New Zealand/
University of Wellington is in New Zealand, not Australia.
Poor sysadmin. Accidentally moved the school too. Sounds like something Harry Potter would do.
Coming soon to a theater near you: Harry Potter and the GNOME Shell.
I got this when I tried to watch the video on the Jeep (Just Empty Every Pocket) video.
This video is private.
If the owner of this video has granted you access, please sign in.
Uhhhhh, NO!
+1
You’re not really missing anything, it was a short vertical-camera tiktok just cursorily showing the damage.
I wonder if the towing directions will be amended to leave the transmission in the highest gear instead of just “in gear”. Then it might have just caused some unnecessary wear and tear rather than complete destruction.
Without pumping oil and coolant it could still destroy the engine, couldn’t it?
The oil pump is almost guaranteed to be mechanically coupled to the crankshaft, usually with a chain. The coolant pump is traditionally driven by the serpentine belt, some new engines, especially hybrids have an electric one.
this makes me wonder if electric cars can get some sort of trickle charge by being towed. i’m probably getting a huge chunk of physics totally wrong here but i’m picturing those old pull-back toy cars.
more than likely you would just disengage the gear, as generating charge would put too much load on the towing vehicle.
It sounds like they accidentally deleted the all the profiles, probably by not sanitizing or verifying the data provided by human resources/finance officials (who might have mistakenly included a wildcard “*” in a spreadsheet at a guess, or sent the wrong file). Always best to archive off data, disable access for at least a month, and then delete it a month after that. That way the data will typically be maintained on offsite tapes for one to several years and can be restored when mistakes are made or access to legacy data is required for legal reasons (e.g. financial information). Snapshots in ONTAP, ZFS or BTRFS is nice also, you can have snapshots automatically taken once an hour for a day, once a day for say 7 days, once a week for a month, and even once a month for a year if the data is valuable enough. Online snapshots are not a replacement for an offsite tape backup, in most ways they do not make your data safer, but they can still be useful if you can avoid their downsides.
He was probably trying to remove former student Bobby Drop Tables
In the US the towed vehicle is referred to as a “dinghy”.
Or a toad
Has no one realised. Auckland is the capital of NZ, not Wellington.
Auckland is the place where the birds say auk. And once they’ve sed awk they’ve gained a perl of wisdom and will bash the shells from the shore.
Whoever uses Windows at an uni…
well, duh.
It was likely central management system, built to ease backup and recovery… It did just that, now they are all recovered to pristine state.
If they keep all of their eggs in one basket, this was bound to happen. Sooner or later.
The vast majority of machines at my uni were running Windows. We did have some Unix workshops, and (I gather, but never saw for myself) some Apple workshops (mainly for graphics work as far as I could tell). Any written coursework I had to submit had to be be submitted along with a digital copy in Word format, some of the courses required us to submit projects that would build in Visual Studio, or other Windows only software.
Well, at least the students have actually learning at university: That offline backups are important.
Uh… “have actually learned something” i meant. Sorry, need more coffee.
As has been explained to a number of VERY Important management types, “Do not store files on local drives”.
Sorry, that’s NOT “your PC”.
I got an oil pan for free from a guy who did the same thing to a vintage Datsun: towed it several km in first gear and obliterated the engine. The oil pan had holes in the sides where the rod big ends had repeatedly smashed into it as they were beginning to fail. Luckily for me, I was going to cut the whole bottom out and rebuild it anyway. There was very little left on the engine that was usable. Even the valve cover had a hole in it. Get a full trailer!
240-Z?
F10?
Ink wiring mimes Juan 2 no!
How did the driver towing the Jeep not notice the drag? It is not easy to push/pull a stalled vehicle when it is in gear.
Found posted by someone else here https://www.youtube.com/watch?v=4szP5IyotFU
