More bad news from Mars this week, and this time not just from Perseverance. Last week the eagerly anticipated first flight of the helicopter Ingenuity was delayed for a couple of days after failing a full-speed spin-up test of its rotors. That appears to have been a bigger deal than initially thought, as it required a significant rewrite of the helicopter’s software. That meant testing, of course, and subsequent upload to the UAV, which at 174 million miles away takes a bit of doing. The good news is that they were able to complete the full-speed rotor test without the full program upload, so we’re one step closer to flight, which may take place as early as Monday morning.
Meanwhile, over at Elysium Planitia, the Mars InSight lander has troubles of its own. The geophysical laboratory, which has been trying to explore the inner structure of Mars since landing in 2018, entered an “emergency hibernation” state this week because of a lack of sufficient power generation. Unlike the radioisotope-powered Perseverance rover, InSight relies on a pair of solar panels for its electricity, and those panels are being obscured by Martian dust. The panels normally get blown clean by Martian winds, but things have been calm lately and the dust has really built up. If this seems like deja vu all over again, it’s probably because a planet-wide dust storm is what killed the plucky Opportunity rover back in 2018. Here’s hoping the wind picks up a little and InSight can get back to work.
Funny what crops up in one’s newsfeed, especially when one is responsible for putting out content that populates others’ newsfeeds. We recently took a look at the dangers of “zinc fever”, a flu-like illness that can crop up after inhaling gasses produced by molten zinc. That resulted in stumbling across an article from last year about mild steel welding fumes being classified as a human carcinogen. This comes from the Health and Safety Executive, a UK government agency concerned with workplace health issues. The release is an interesting read, and it suggests that mild steel fumes can cause not only lung cancer but kidney cancer. The announcement is mainly concerned with British workplaces, of course, but there are some interesting tidbits in there, such as the fact that welding fumes make dust particles so small that they can reach down into the very lowest reaches of lungs, the alveoli where gas exchange occurs. It’s enough to make one invest in PAPR or some kind of fume extractor.
For those of a certain vintage, our first computer was probably something that bore little resemblance to a PC or laptop. It was likely a single-board affair or something like a C64, and acquiring the essential bit of hardware usually left little in the budget for a proper monitor. Little 12″ B&W TVs were a dime a dozen, though, and easily — if grainily — enlisted into service as a monitor by way of an RF modulator. To recreate a little of that magic with modern hardware, Hackaday contributor Adam Zeloof came up with the PiMod Zero, an RF-modulator hat for the Raspberry Pi Zero that turns the component video into an NTSC analog signal. He’s open-sourced the design files, or there’s a CrowdSupply campaign for those who prefer to buy.
And finally, if you somehow traveled back in time to the 1940s with a laptop, how long would it have taken you to crack the Enigma code? Longer than you think, at least according to Dr. Mike Pound over at Computerphile, who released a fascinating video on how Enigma worked and what it took for Turing and the gang at Bletchley to crack the code. We knew some of the details of Enigma’s workings before seeing this video, but Mike’s explanation was really good. And, his explanation of the shortcut method he used to decode an Enigma message made the whole process clearer to us than it’s ever been. Interesting stuff.
I like the PiMod Zero rf modulator, just a couple of questions, how hard is it to get higher VHF channels and the same for PAL? Oh and if you want to play with old encryption machines there is a website with OLD (XP old) simulations of a crapload of encryption machines, Enigma, Sigaba, Typex and I believe a pig latin typewriter.
http://users.telenet.be/d.rijmenants/index.htm
How much higher? Channels 2-6 should be achievable without too much effort – just finding a source of the correct SAW resonators. For the most part, this is “just” relying on the NJM2519A to do the modulation, with an external SAW resonator to set the frequency, and an external LC tank to set the audio offset frequency above and below.
The datasheet for the NJM2519A doesn’t say how high of frequency it can go, but I wouldn’t be surprised if it has troubles with the upper band of VHF or any UHF.
The datasheet doesn’t say PAL is doable, but you might just be able to tune the 4.5MHz audio tank up to 5.5 or 6MHz depending on which PAL standard you want.
Television sets of a certain vintage in this country will not do NTSC. You get a continuously scrolling frame because the Vsync ends sooner than the television is expecting.
So, nice idea, maybe useful if your television is of a mid-90s vintage or newer… but useless for the monochrome sets mentioned in the article since those will all expect 625 lines.
The field timing comes from the Pi here, and you can configure it for PAL. The only thing the hat here is doing is taking baseband CVBS and audio and modulating the audio FM and then modulating both AM.
Change the 61.25MHz SAW (US TV channel 2) resonator for a 61.75 / 62.25 / 60.5 / 60.25 / 59.25 / 64.25 SAW depending on where exactly the TV came from, and it should modulate that CVBS video – as long as it’s the correct 625-line input – to something a TV can understand.
Change the LC tank for audio from 4.5MHz (System M audio-to-video-carrier spacing) to 5, 5.5, 6, 6.5, or 7 MHz similarly.
And there were some of us who, before RF modulators became cheap enough, probed the innards of an old TV with a capacitor held by a well-insulated pliers. It worked, but it was risky, especially with a hot-chassis set.
Couldn’t have said it better myself.
The story of breaking Enigma is really fascinating. It was huge effort of Polish and British mathematicians, but also a lot of undercover operations, which provided a lot of German documents, which were instrumental in breaking the cipher.
Dermot Turing, nephew of Alan, wrote a book “X, Y & Z: The Real Story of How Enigma Was Broken” telling the entire story. Even though I was pretty well familiar with work the Polish and British cryptologists did, I learned a lot of new information from it.
I highly recommend it to anyone who is interested in the history of breaking Enigma.
Not sure of the distances involved, but how about you fly Perseverance over to InSight, and use the prop wash to clean the solar panels??
Google says the distance is somewhere around 3500km, that’s a long way for a real helicopter to fly let alone a battery powered ‘drone’.
Re Mars solar panels, you would think that by now tilting solar panels would be a standard deal. Or something like windshield wiper.
If there is so much wind, why not mini wind turbines?
Or converting any propellers to gain power?
I’ve not found any mention of various methods of welding mild steel having more or less serious effects
It’s be interesting to find out whether oxy acetalene welding produces different fumes to a method that uses shielding gasses
