ISS Gets Roll-Out Solar Panels In Post-Shuttle Fix
Astronauts are currently installing the first of six new solar arrays on the International Space Station (ISS), in a bid to bolster the reduced power generation capability of the original panels which have now been in space for over twenty years. But without the Space Shuttle to haul them into orbit, developing direct replacements for the Stations iconic 34 meter (112 foot) solar “wings” simply wasn’t an option. So NASA has turned to next-generation solar arrays that roll out like a tape measure and are light and compact enough for the SpaceX Dragon to carry them into orbit.
Space Shuttle Atlantis carrying part of the ISS truss.
Considering how integral the Space Shuttle was to its assembly, it’s hardly a surprise that no major modules have been added to the ISS since the fleet of winged spacecraft was retired in 2011. The few small elements that have been installed, such as the new International Docking Adapters and the Nanoracks “Bishop” airlock, have had to fit into the rear unpressurized compartment of the Dragon capsule. While a considerable limitation, NASA had planned for this eventuality, with principle construction of the ISS always intended to conclude upon the retirement of the Shuttle.
But the International Space Station was never supposed to last as long as it has, and some components are starting to show their age. The original solar panels are now more than five years beyond their fifteen year service life, and while they’re still producing sufficient power to keep the Station running in its current configuration, their operational efficiency has dropped considerably with age. So in January NASA announced an ambitious timeline for performing upgrades the space agency believes are necessary to keep up with the ever-increasing energy demands of the orbiting laboratory.
Made in the Shade
Replacing the Station’s original “Solar Array Wings”, or SAWs, with new ones isn’t really an option. For one thing, they’re far too large. Even in their retracted position, each SAW is more than 4.5 m (15 ft) long, considerably larger than what can be fit into the Dragon’s trunk. SpaceX likely could have come up with some Dragon variant capable of carrying expanded payloads, as they’ve already been contracted to do as part of the Artemis lunar program, but the time and cost involved would have been prohibitive.
But more importantly, removing the SAWs would be a massive undertaking that would undoubtedly be plagued with unexpected problems. The first step would be retracting them, but as pulling just one of the arrays in turned out to be a six hour nightmare when ground controllers last attempted it in 2006, the chances of getting all eight of them collapsed into a more manageable configuration would seem pretty poor. Plus the procedure would need to be done without disrupting normal operations aboard the Station, and afterwards, the old panels would need to be safely disposed of in some way.
Approximate size of new panels compared to original SAW.
Instead, NASA decided to take the easy way out: rather than actually replacing the old panels, they would simply install smaller panels directly on top of them. By not altering the original SAWs, the installation procedure would be far safer for the Station, and it would also allow the new panels to take advantage of the existing sun-tracking mounts. Naturally this means a sizable portion of the original SAWs would be in permanent shade, but given the higher efficiency of the new panels, it still ends up being a net positive in terms of energy production.
But that only solves half of the problem. These new solar arrays would still need to be compressed into a form small and light enough to fit into the back of the Dragon.
Rolling Out ROSA
The solution, developed through a collaboration between the Air Force Research Laboratory and Deployable Space Systems, is the Roll Out Solar Array (ROSA). Without the rigid strictures and hinges used in traditional deployable solar arrays, the ROSA can be stowed as a tight cylinder and unrolled once moved into its final position. The integrated booms on either side of the solar panels are made of a composite material, and are able to unfurl the array using nothing more than the potential energy stored when they were coiled up on the ground. This capability makes them highly reliable, and holds particular promise for future applications where human intervention may not be possible.
A prototype ROSA being tested on the ISS in 2017.
The first two ROSAs arrived at the Station earlier this month as part of the SpaceX CRS-22 mission, with the other four expected to be delivered before the end of the year. Installation of each ROSA requires two spacewalks, one to install a modification kit to the existing SAW structure, and the other to mount and unfurl the panel. NASA says that when deployed, each of the 18 m (60 ft) ROSAs will produce approximately 20 kilowatts; roughly equivalent to what each degraded SAW is currently delivering.
Astronauts prepare the first ROSA for installation.
Technically there’s no reason ROSAs couldn’t be installed over all eight of the original SAWs, but at least for the time being, NASA believes the additional 120 kilowatts the ISS will receive with six upgraded arrays will be enough to meet current and future power demands. It’s also likely that, in classic NASA fashion, they want to keep one pair of SAWs in their original configuration on the off chance that there is a problem with the modified arrays.
But the International Space Station is just the beginning. Assuming they work as expected in low Earth orbit, NASA plans on installing similar roll out arrays on the Gateway lunar outpost. This small space station will serve as a rallying point for astronauts travelling to and from the Moon’s surface, as well as a proving ground for the next-generation technology that could eventually take humans to Mars and beyond.
18 thoughts on “ISS Gets Roll-Out Solar Panels In Post-Shuttle Fix
      1. I’d like to see more on the efficiency decay, including terrestrial panels. Efficiency decay is the main reason keeping me away from photovoltaic. Solar thermal is something I’d install in a heartbeat.
        1. Solar thermal has moving parts and thus maintenance and other issues will cause you far more losses and problems than the loss in efficiency from photovoltaics over time.
  1. And let us not forget that they previously replaced the station’s great array of outdated backup batteries with newer ones. Ones that are quite familiar to us all. Big boxes of of LiPo batteries. That station has been up there long enough to be granted a special award of some sort.
      1. I have an advanced one of those roll out devices – when you roll the towel out in the sun it can directly use the suns energy to dry! All without electronic control!
    1. Many readers likely had the same thought. But to drag the old arrays to the atmosphere requires propulsion of some sort, which has risks… getting it up there… human handling… attaching it… then firing the thruster. No part of this thruster and solar array must reach the earth’s surface to cause damage, else liability. What if a slow moving array, the size of which is large, were to intercept a LEO? Liability ensues. So I’d naively guess that a lot of space solutions may be nixed by stewardship and the liability that comes from playing odds.
  2. What are the effiency of space panels today? and what was it on the old ones when they were new?
    I know that NASA pays twice as much for a panel that is a few % more efficient without hesitation.
    Space (hehe) is a premium, any space and weight saving is worth a lot for them, and they have the funds to buy the very best
    And I, here on terra firma, I would gladly drape all of my roof with a cheap panel that is a few % less efficient, to save a buck.
    There is a need for both, but undoubtly the space panels are the top notch ones.
    Do they use other wavelength light? Multiple wavelengths? Light that is stopped by the atmosphere from reaching earth?
    There is a full story for Hackaday here, if you just shine some light on the topic…. Badum tssh
Leave a Reply to Chris MapleCancel reply
