Modular Anti-Drone Drone Sacrifices Itself For Self Defense
Part Racing Drone, Part RC Airplane, Part Rocket…all Menace. How else could you describe a quadcopter that shoots off at high speed and is designed for taking down other small quadcopters? The Interceptor Drone by [Aleksey] borrows elements from all of the aforementioned disciplines of flying things.
Built with standard racing drone parts, [Aleksey] assures that no prohibited parts are used in its construction. Instead, the Interceptor Drone relies on a very powerful motors and a light weight frame to keep the power to weight ratio in the “rocketing into the sky” category.
A close up shows the details: Detachable motors and rotors and the stowed net.
But what Interceptor Drone would be complete without a way to take its target out of the sky? This is where the biggest divergences begin. The motors are all oriented to point away from the center-line of the craft. Upon command, these motors actually detach from the frame, each spreading out and deploying the corner of a net that’s designed to entangle the rotors of the target, causing its battle with gravity to come to a grinding halt.
How does the Interceptor Drone survive the attack? Without its motors, the core of the quadcopter falls to the earth. Arresting the fall is a parachute much like those used in model rocketry. An audio beacon sounds the alarm to help somebody to find it — a move taken straight from the RC aircraft hobby.
There’s certainly a lot of room to discuss legalities in localities, but regardless of opinion about the craft’s intended use, the system looks very slick, and there are some great hacks baked right in. Don’t want to build a drone-killing-drone? Maybe all you need is a pumpkin and good (bad?) timing.
Thanks [Chris] for the tip.
18 thoughts on “Modular Anti-Drone Drone Sacrifices Itself For Self Defense
  1. Great idea. I have never really wanted a drone until just now. I hope the price is right, because I want a bunch of these.
    The only thing worse than drones is electric bikes. Maybe these can be deployed against electric bikes?
  2. Porch pirates are now investing in this type of drone to hijack amazon deliveries before they arrive.
    We will need anti-anti-drone drone drones!
    I am looking forward to seeing amazon’s counter-attack plan. This is going to happen.
Leave a Reply to ChrisCancel reply
