Minecraft In Minecraft On The CHUNGUS II
Minecraft is a simple video game. Well, it’s a simple video game that also has within it the ability to create all of the logic components that you’d need to build a computer. And building CPUs in Minecraft is by now a long-standing tradition.
Enter CHUNGUS II. The Computational Humongous Unconventional Number and Graphics Unit by [Sammyuri] is the biggest and baddest Minecraft computer that we’ve ever seen. So big, in fact, that it was finally reasonable to think about porting a stripped-down version of Minecraft to the computer itself. Yes, that’s right, Minecraft running in Minecraft. (Video embedded below.) Writing the compiler and programming the game brought two more hackers to the party, [Uwerta] and [StackDoubleFlow], and quite honestly, we’re amazed that a team as small as three people pulled this off.
Anyway, once you’ve picked your jaw up off the floor, also check out [Sammyuri]’s video on just the CHUNGUS II computer itself. (Also embedded below.) Seeing the architecture is interesting, even if you don’t speak Redstone as fluently as our heroes here. We love that the assembler creates a block of ROM – out of Minecraft blocks – that you can then cut/paste into the game’s reality.
For a “simple” game about breaking blocks and punching trees, Minecraft has inspired hackers to make the game better both inside and outside of the real world. For instance, for the latest in performant open-source Minecraft servers, check out Folia. Maybe, one day, they’ll build CHUNGUS II in the real world. It could happen.
Thanks [dbcdr] for the tip!
16 thoughts on “Minecraft In Minecraft On The CHUNGUS II
    1. It´s a luck that HaD does not accept images in the comments otherwise you guys would pollute the comment with idiotic memes belonging to Hollywood and TV series “culture”.
  1. How long until Chungus supports redstone and the guys create a Chunception running Chungus in minecraft in chungus in minecraft.
    1. A shivering fear just emerged, one that makes one pause and consider…
      What if something like this created a reality loop that trapped dimensions and formed the boundary lines of existence?
      Then we’d be lamenting the event as something that constrained everything…
      Something preventable, yet unstoppable.
  2. If people keep recursively running things inside of itself, I’m afraid one day it will result in a singularity and POOF! Existence stops existing.
  3. Making a computer using command blocks to do logic is cheating and doesn’t count.
    Otherwise, you could just do it in a single modded block, since the Minecraft version they run in game isn’t the stock one and therefore it already is “modded Minecraft”
    1. Yeah. Making a computer using transistors and even integrated circuits was the worst kind of cheating. Imagine, instead of using 6.5V and 350V, they only used 5V. Not authentic at all. And people took it way too far even after that, putting everything in one small black box and even running it on only 1.8V! Nothing original, it’s all ‘modded electronics’. :(
Leave a Reply to EricCancel reply
