2023 Cyberdeck Challenge: CyberTapeDeck
There seem to be two schools of thought when it comes to picking an enclosure for your cyberdeck project: you either repurpose the carcass of some commercially produced gadget, or you build a new case yourself. The former can lead to some very impressive results, especially if your donor device is suitably vintage, but the latter is far more flexible as the design will be based on your specific parameters.
But for the CyberTapeDeck, [Matthew] decided to take a hybrid approach. The final product certainly looks like it’s built into a 1980s portable tape deck, but on closer inspection, you’ll note that the whole thing is actually 3D printed. The replica doesn’t just nail the aesthetics — it also includes the features you’d expect from the real thing, including an extendable handle and functional buttons which the internal Raspberry Pi 3 sees as a macropad thanks to an Arduino Pro Micro.
A seven inch LCD stands in for the tape door, and while it unfortunately doesn’t look like [Matthew] was able to replicate the opening mechanism to angle the display, you can at least stand the whole thing on its end to provide a more comfortable viewing experience.
[Matthew] says one of the intended purposes for this cyberdeck is to get his son excited about working with electronics and programming, so in a particularly nice touch, he’s mounted a terminal block over the “speaker” that ties into the Pi’s GPIO pins. This provides a convenient interface for experimenting on the go, without getting tangled up in exposed wiring.
We appreciate that [Matthew] has released the STL files for all of the printed parts, because even though it makes a great cyberdeck, the design is begging to house a faux-retro media player.
9 thoughts on “2023 Cyberdeck Challenge: CyberTapeDeck
  1. ” he’s mounted a terminal block over the “speaker” ”
    And that was the reason for the uncanny Valley when I saw it.
  2. My first impulse was, “This guy needs to be shut down for destroying one of the last few million remaining Panasonic RQ-309s,” but then, wait, that’s not right…
    The 70s are strong with this one. Got the vibe exactly right on this.
    But I also have that keyboard, and it sucks! They shifted the bottom row the wrong direction in trying to get the hinge to work, causing me to misspell everything. I mean literally. It comes out “ecrythibg”.
  3. I dream about cyberdeck with ssh, keyboard, screen and few weeks working time. Nothing more.
    Why we love cyberdeck? Because is mobile, usefull and durable. no need fast, multicolor etc.
    1. When I lived in Germany I had a Kindle 3 (later known as Kindle Keyboard) to more easily access English language books (and make use of the free worldwide internet access). It had an ‘experimental’ web browser built in, and could be hacked to allow music playback, even internet streaming radio. Using it as an SSH client was a bit rough, but it did get me out of some spots of bother. It’s probably better than any ‘cyberdeck’ design I’ve had in mind.
      1. i have kindle keyboard
        ssh not working, BTW screen is too slow for this, cellular communication are stoped many years ago
    1. Don’t know if “cookin” is the best term. Most of the audio tape data storage formats operated at less than 1000 bits/second.
Leave a Reply to eryhh5h34e5yheCancel reply
