RNODE: A Portable Unrestricted Digital Radio
A portable digital radio transceiver in a 3d printed case
RNode is an open source, unrestricted digital radio transceiver based on — but not limited to — the Reticulum cryptographic networking stack. It is another interesting project in what we might call the “Federated application” space in that it is intended to be used with no central controlling body. It can be used in a LAN or WAN context with the Reticulum network when operating in network adaptor mode, but it also has other use cases.
Essentially, RNode is a software project running on a LilyGO LoRa32 board wrapped up in a snazzy-looking 3D-printed case. Just make sure to grab a version of the board with an u.FL connector in place or somewhere to solder one. If it comes with an SMA connector, you will want to remove that. The device can be standalone, perhaps attached to a mobile device via Wi-Fi, but it needs to be hooked up to a laptop for the really interesting applications. When set to TNC mode, it can act as an APRS gateway, which allows you to access packet radio BBSs and all that fun stuff.
Other supported applications are Sideband and the Nomad Network, both LXMF clients for messaging over secure peer-to-peer networks. Finally, the LilyGo board is a LoRa device that can act as a general-purpose LoRa sniffer, useful for finding communication dead spots. One fun idea is the “bootstrap console,” accessible via any Wi-Fi-enabled RNode and contains the basic information needed to construct other RNode devices. This is hosted on the device, so no internet access is required. But you need access to the spare parts, tools, and something with a screen to read it on. Still, it’s an interesting concept enabled by modern embedded devices having plenty of storage on tap.
The idea of using LoRa for communications at the human level is not a new one. We covered this nice blackberry-esque build not long ago. If you want to know how far you can go with LoRa, check this out.
Thanks [Adam] for the tip!
10 thoughts on “RNODE: A Portable Unrestricted Digital Radio
    1. Based on a quick read of their respective websites it seems that this project is much more flexible and powerful than meshtastic.
      1. yeah the fact it can drop into a TNC mode is nuts. like when you get sick of just text messaging you can start doing all sorts of silly stuff, like this thing can straight up be a serial modem for projects completely sidestepping any implementation in hardware and blast out data over a serial port. kind of magical little thing!
  1. This looks great however the first question that comes to my mind is will it cooperate with meshtastic networks. What I mean is will they forward each other’s traffic and participate in each other’s meshes?
    Given the recent explosion in popularity of Meshtastic, it seems like that would be a good idea if you want your RNodes to have reach.
    1. I warmly encourage some communication between the two projects to hack gateway together!
      Definition of how one request from a device on a network becomes onto the other.
      1. I don’t think that has any thing to do with the question. It may be mediocre but you may already have Meshtastic mesh deployed that you may want to connect to and participate in with your new rnode.
        It’s a rough example but there are many situations where someone with an RNode may want it to cooperate with the more mediocre mesh
  2. restricted to restricted band
    I need armachat layout witrh reticulum in C
    and communicator : tox, wire, matrix connector
  3. I bought a few devices to play with lora, but had trouble with the web page being very confusing and hard to navigate so my t-deck is missing the lora chip. Can the devices alternate between meshtastic and rnode by reflashing so we don’t have to guess which will be the winner.
Leave a Reply to philosiraptor117Cancel reply
