Long-Awaited SLS4All 3D Printer Now Shipping
We touched on the open source SLS4All DIY SLS 3D printer a year or two ago when the project was in the early stages. Finally, version one is complete, with a parts kit ready to ship and all design data ready for download if a DIY build or derivative is your style. As some already mentioned, this is not going to be cheap: with the full parts kit running at an eye-watering $7K before tax. But it’s possible to build or source almost all of it a bit at a time for those on a budget.
Try printing THIS benchy on an FDM machine!
It’s important to note that to access the detailed information, you’ll need to create an account, which is a bit inconvenient for an open source design. However, all the essential components seem to be available, so it’s forgivable. In terms of electronics, there are two custom PCBs: the GATE1 (GAlvo and Temperature Control) and the ZERO1 (Zero-crossing dimming) controller. Other than that, all the electronics seem to be standard off-the-shelf components. Both of these PCBs are designed using EasyEDA.
Unfortunately we couldn’t find access to the PCB Gerbers, nor does there appear to be a link to their respective EasyEDA projects, just the reference schematics. This is a bit of a drawback, but it’s something that could easily be reproduced with enough motivation. Control is courtesy of a Radxa Rock Pi, as there were ‘problems’ with a Raspberry Pi. This is paired with a 7-inch touchscreen to complete the UI. This is running a highly modified version of the Klipper together with their own control software, which is still undergoing testing before release.
The laser head is built around a 10 W 450 nm laser module from China and a high-end galvanometer set. Two 200 W halogen tube heaters heat the print bed, and 200 W silicone heating pads heat both the powder bed and the print bed.
Continue reading “Long-Awaited SLS4All 3D Printer Now Shipping”
Raspberry Pi Saves Printer From Junk Pile
Around here, printers have a life expectancy of about two years if we are lucky. But [techtipsy] has a family member who has milked a long life from an old Canon PIXMA printer. That is, until Microsoft or Canon decided it was too old to print anymore. With Windows 10, it took some hacking to get it to work, but Windows 11 was the death knell. Well, it would have been if not for [techtipsy’s] ingenuity with a Raspberry Pi.
The Pi uses Linux, and, of course, Linux will happily continue to print without difficulty. If you are Linux savvy, you can probably see where this is going.
Continue reading “Raspberry Pi Saves Printer From Junk Pile”
