What You Can See With A SEM?
The last time we used a scanning electron microscope (a SEM), it looked like something from a bad 1950s science fiction movie. These days SEMs, like the one at the IBM research center, look like computers with a big tank poised nearby. Interestingly, the SEM is so sensitive that it has to be in a quiet room to prevent sound from interfering with images.
As a demo of the machine’s impressive capability, [John Ott] loads two US pennies, one facing up and one face down. [John] notes that Lincoln appears on both sides of the penny and then proves the assertion correct using moderate magnification under the electron beam.
Some electron microscopes pass electrons through thin samples much as light passes through a sample on a microscope slide. However, SEMs and REMs (reflection electron microscopes) use either secondary electron emission or reflected electrons from the surface of items like the penny.
You often see SEMs also fitted with EDS — energy dispersive X-ray spectrometers, sometimes called EDX — that can reveal the composition of a sample’s surface. There are other ways to examine surfaces, like auger spectrometers (pronounced like OJ), which can isolate thin films on surfaces. There’s also SIMS (secondary ion mass spectrometry) which mills bits of material away using an ion beam. and Rutherford backscattering spectrometry, which also uses an ion beam.
We keep waiting for someone to share plans to make a cheap, repeatable SEM. There are a few attempts out there, but we don’t see many in the wild. While the device is conceptually simple, you do need precise high voltages and high vacuums,. Also, you frequently need ancillary devices to do things like sputter gold in argon gas to coat nonconductive samples, so the barrier to entry is high.
4 thoughts on “What You Can See With A SEM?
  1. I remember those great hulking cantankerous EMs too. But Hitachi (and others) have had nice tabletop SEMs for more than 25 years now. Originally looking like a cube minifridge back then, they are even smaller now: https://www.hitachi-hightech.com/ca/en/products/microscopes/sem-tem-stem/tabletop-microscopes/tm4000ii.html
    Their coolest trick (or *was* cool, a quarter century ago) is not requiring conductive samples: Their bug/feature is they didn’t pull a ‘perfect’ (*) vacuum: Pumpdown times were very short, and the residual gas got ionized and provided the current return path.
    ( * ‘Perfect’ in the context of TEM is: few enough gas molecules left that the probability of an electron hitting a gas molecule on the way to the target is close enough to zero that electrons scattered by those collisions do not degrade the image significantly. Conventional SEMs are a little more forgiving, but this ‘new’ class of small SEMs operate with orders of magnitude higher gas pressure.)
  2. SEMs are not that sensitive with sound… Talking in the room is fine for example. With a TEM you should not move much when acquiring images though :)
    As a replacement for gold sputters, Carbon coaters are relatively simpler devices (carbon rods heated up in moderate vacuum). Some SEMs might operate in Low vacuum as well and less conductive samples(ceramics, organics) may be examined with no conductive coating.
  3. Fun Fact: Chemists call it EDS because they like spectroscopy. Physicists call it EDX because they like X-Rays.
  4. The ‘x’ in magnification and calculation is pronounced ‘times’ and not freaking ‘ex’
    They are suppose to teach that in primary school.. or before.
