A month ago, I’ve talked about using computers to hack on our day-to-day existence, specifically, augmenting my sense of time (or rather, lack thereof). Collecting data has been super helpful – and it’s best to automate it as much as possible. Furthermore, an augment can’t be annoying beyond the level you expect, and making it context-sensitive is important – the augment needs to understand whether it’s the right time to activate.
I want to talk about context sensitivity – it’s one of the aspects that brings us closest to the sci-fi future; currently, in some good ways and many bad ways. Your device needs to know what’s happening around it, which means that you need to give it data beyond what the augment itself is able to collect. Let me show you how you can extract fun insights from collecting data, with an example of a data source you can easily tap while on your computer, talk about implications of data collections, and why you should do it despite everything.
As we get older, our eyes get worse. That’s just a fact of life. It is a rite of passage the first time you leave the eye doctor with a script for “progressive” lenses which are just fancy bifocals. However, a new high-tech version of bifocals promises you better vision, but with a slight drawback, as [Sherri L. Smith] found.
Remember how users of Google Glass earned the nickname “glassholes?” Well, these new bifocals make Google Glass look like a fashion statement. If you are too young to need them, bifocals account for the fact that your eyes need different kinds of help when you look close up (like soldering) or far away (like at an antenna up on a roof). A true bifocal has two lenses and you quickly learn to look down at anything close up and up to see things far away. Progressives work the same, but they transition between the two settings instead of having a discrete mini lens at the bottom.
The new glasses, the ViXion01 change based on what you are looking for. They measure range and adjust accordingly. For $555, or a monthly rental, you can wear what looks like a prototype for a Star Trek visor and let it deduce what you are looking at and change its lenses accordingly.
Of course, this takes batteries that last about ten hours. It also requires medical approval to be real glasses and it doesn’t have that, yet. Honestly, if they worked well and didn’t look so dorky, the real use case might be allowing your eye doctor to immediately download a new setting as your vision changes. How about you? How much odd headgear are you willing to wear in public and why?
After previously working out a suitable approach to create a period-correct paper tape reader for his tube-based, MC14500B processor-inspired computer, [David Lovett] over at the Usagi Electric farm is back with a video on how he made a working tape reader.
The assembled paper tape reader as seen from the front with tape inserted. (Credit: David Lovett, Usage Electric, YouTube)
The tape reader’s purpose is to feed data into the tube-based computer, which for this computer system with its lack of storage memory means that the instructions are fed into the system directly, with the tape also providing the clock signal with a constant row of holes in the tape.
Starting the tape reader build, [David] opted to mill the structural part out of aluminum, which is where a lot of machining relearning takes place. Ultimately he got the parts machined to the paper design specs, with v-grooves for the photodiodes to fit into and a piece to clamp them down. On top of this is placed a part with holes that line up with the photodiodes.
Another alignment piece is added to hold the tape down on the reader while letting light through onto the tape via a slot. After a test assembly [David] was dismayed that due to tolerance issues he cracked two photodiodes within the v-groove clamp, which was a hard lesson with these expensive (and rare) photodiodes.
Although tolerances were somewhat off, [David] is confident that this aluminum machined reader will work once he has it mounted up. Feeding the tape is a problem that is still to be solved. [David] is looking for ideas and suggestions for a good approach within the limitations that he’s working with. At the video’s end, he mentions learning FreeCAD and 3D printing parts in the future. That would probably not be period-correct in this situation, but might be something he could get away with for some applications within the retrocomputing space.
We covered the first video and the thought process behind picking small (1.8 mm diameter) photodiodes as a period-correct tape hole sensor for a 1950s-era computing system, like the 1950s Bendix G-15 that [David] is currently restoring.
