Origami-Inspired, Self-locking Structures With 3D Printing
Researchers recently shared details on creating foldable, self-locking structures by using multi-material 3D printing. These origami-inspired designs can transition between flat and three-dimensional forms, locking into place without needing external support or fasteners.
The 3D structure of origami-inspired designs comes from mountain and valley fold lines in a flat material. Origami designs classically assume a material of zero thickness. Paper is fine, but as the material gets thicker things get less cooperative. This technique helps avoid such problems.
An example of a load-bearing thick-film structure.
The research focuses on creating so-called “thick-panel origami” that wraps rigid panels in a softer, flexible material like TPU. This creates a soft hinge point between panels that has some compliance and elasticity, shifting the mechanics of the folds away from the panels themselves. These hinge areas can also be biased in different ways, depending on how they are made. For example, putting the material further to one side or the other will mechanically bias that hinge to fold into either a mountain, or a valley.
Thick-panel origami made in this way paves the way towards self-locking structures. The research paper describes several different load-bearing designs made by folding sheets and adding small rigid pieces (which are themselves 3D printed) to act as latches or stoppers. There are plenty of examples, so give them a peek and see if you get any ideas.
We recently saw a breakdown of what does (and doesn’t) stick to what when it comes to 3D printing, which seems worth keeping in mind if one wishes to do some of their own thick-panel experiments. Being able to produce a multi-material object as a single piece highlights the potential for 3D printing to create complex and functional structures that don’t need separate assembly. Especially since printing a flat structure that can transform into a 3D shape is significantly more efficient than printing the finished 3D shape.
2 thoughts on “Origami-Inspired, Self-locking Structures With 3D Printing
  1. This looks like interesting work, and hopefully will lead to design tools to make it more accessible. I would add that 3D printing isn’t the only way to do this, or the best necessarily.
    I’ve tinkered a bit with similar structures, using recycled polyester screen-printing mesh as the living hinge layer. It’s very thin, very strong, and easy to source even if you have to buy it. You can sandwich it between CNC’d plywood sheets, or print the rigid panels onto the mesh directly. The CNC option gives a great result and is fast; printing is a bit more fiddly, but you can have arbitrary bevel angles, and you could also make the stoppers mentioned in the OP (which are an interesting idea).
    1. Very cool! First time stumbling across this site. Just went down a google rabbit hole.
      I’m just starting to brain storm here. I want to figure out a way to make a stable and ridged panel about the size of a beach towel that can fold/roll-up to be portable and light. Strong enough to stay stable and ridged when an adult stands on it even when laid down on beach sand or grass.
      I’m thinking an origami style folding pattern is the key. Maybe perforations/indentations stamped into some type of plastic that automatically cause the platform to open/close efficiently to achieve the goal. (Think: roll-up yoga mat or small folded square that morphs into a solid board. The more novel and “fun” the deploy/retract action is the better.
      Any tips would be greatly appreciated. I’m trying to help a buddy improve something he designed but is wayyyyy too cumbersome to transport. (I didn’t tell him I’m doing this ha)
Leave a Reply to BobtatoCancel reply
