Keebin’ With Kristina: The One With The Curvy Centerfold
Illustrated Kristina with an IBM Model M keyboard floating between her hands.
What do you get when you combine a Raspberry Pi 4B, a Kaypro keyboard, and a 9″ Apple ], you get the coolest AVR development workstation I’ve seen in a while.
A Raspberry Pi-based AVR workstation that uses a Kaypro keyboard and 9" monochrome Apple ][c display.
Image by [John Anderson] via Hackaday.IO
As you may have guessed, I really dig the looks of this thing. The paint job on the display is great, but the stripes on the keyboard and badging on are on another level. Be sure to check out the entire gallery on this one.
About that keyboard — [John] started this project with two incomplete keyboards that each had a couple of broken switches. Since the two keyboards were compliments of each other parts-wise, they made a great pair, and [John] only had to swap out three switches to get it up and clacking.
In order to make it work with the Pi, [John] wrote a user-mode serial driver that uses the uinput kernel module to inject key events to the kernel. But he didn’t stop there.
Although the Pi supports composite video out, the OS doesn’t provide any way to turn off the chroma color signal that’s modulated on top of the basic monochrome NTSC signal, which makes the picture look terrible. To fix that, he wrote a command-line app that sets up the video controller to properly display a monochrome NTSC signal. Happy AVRing on your amazing setup, [John]!
Check Out This Refreshingly Small Keyboard
Half of a keyboard, fit inside an Altoids tin.
Image by [AnnaRooks] via reddit
Usually when we see keyboards this small, they have tiny keys that are fully intended for thumb presses and thumb presses only. But what about something ultra-portable that has full-size keys?
Although it might be hard to believe, [AnnaRooks] only uses about 20 of the 24 keys that make up this mint tin keyboard. She has a keymap for typing, gaming, and Diablo II.
Personally, and my feelings about layers aside, I don’t think I could use a keyboard without thumb clusters at this point. Although you know what? It would make a great traveling macropad.
The Centerfold: A Close Look At Force Curves
A keyboard switch force tester and a bunch of different switches.
Image by [ThereminGoat] via reddit
Well, boys and girls, we’ve got a smart beauty this time around. This here is an industrial key switch force tester. [ThereminGoat] is gonna tell you all about force curves and how to read them.
What even is a force curve, and why is it so important? It refers to the graphical representation of the force required to press a key to the actuation point (y) versus the distance traveled during the press (x). So, it’s only critical to evaluating key switch performance. Key points along the force curve include the starting force, the actuation point, the tactile bump if present, the bottom-out force, and the return curve.
So, why does it actually matter? Force curves help us understand how light or heavy a switch feels, the actuation behavior, and help with customization. I’ll let [ThereminGoat] take it from here.
Do you rock a sweet set of peripherals on a screamin’ desk pad? Send me a picture along with your handle and all the gory details, and you could be featured here!
Historical Clackers: My IBM Wheelwriter 5
You know, I kind of can’t believe that I’ve now gone 47 Keebins without spotlighting my daily driver, which takes up most of my second desk. She may not look like much, but she types like the wind, and has that legendary buckling-spring keyboard to boot.
A moody shot of an IBM Wheelwriter 5 electronic typewriter.Sure, the Selectrics get all the love, and rightfully so. But if you actually want to use a typewriter day in and day out, you really can’t beat its successor, the Wheelwriter. IBM produced these machines from 1984 to 1991, and Lexmark took over, cranking them out until 2001. Mine shows an install date of 4/22/85.
The Wheelwriter was IBM’s first daisy wheel typewriter, which replaced the golf ball type element that signified the Selectric. Arguably even easier to swap than the golf ball, these slim cartridges lay flat for easy storage.
Whereas the Selectric used a mainspring and an escapement like traditional machines, the Wheelwriter has a stepper motor that moves the print head and a solenoid that strikes the daisy wheel against the paper. It makes a delightfully frightening noise on startup as it tests the stepper and solenoid and spins the daisy wheel with alarming swiftness. I love this machine!
ICYMI: Updated Mouse Ring Now Uses Joystick
A Bluetooth mouse in ring form.Are you tired of traditional mouse and keyboard input, even though you’ve got a sweet ergo split and a trackball? Maybe you’re just looking to enhance your VR setup. Whatever you’re into, consider building [rafgaj78]’s Mouse Ring.
As you might be able to discern from the picture, this baby is based on the Seeed Xiao nRF52840 and uses a tiny battery pack. This is version two of the ring mouse, so if you prefer buttons to a joystick, then the first iteration may be more your style. Keep in mind that version two is easier to assemble and comes in more ring sizes.
There are two modes to this mouse ring. In the first mode, the joystick does left and right mouse click and wheel up-down, and pushing will wake it from deep sleep. In the second mode, the joystick acts as the mouse pointer, and you push down to left click.
I love the elegant design of the ring itself, and it looks great in yellow. Hmm, maybe I need one of these…
Got a hot tip that has like, anything to do with keyboards? Help me out by sending in a link or two. Don’t want all the Hackaday scribes to see it? Feel free to email me directly.
7 thoughts on “Keebin’ With Kristina: The One With The Curvy Centerfold
  1. I’m using my Pi 3B+ with a PAL black and white TV, does anyone know if it’s worth trying this approach on that too or is the problem/solution NTSC-specific?
    1. I’d try and run it straight as they specified even though it’s NTSC. Worth a try, though it might mess up the aspect ratio a bit. I’ve also seen someone use an HDMI-to-VGA adapter and take just one of the color signals from the VGA output.
      And obviously the single biggest improvement for legibility would be to set the resolution to something sane for that display, and maybe pick a system font designed with early CRTs in mind
    2. The pivec app (https://github.com/racerxr650r/pivec) just sets the VEC bits to disable the color burst and chroma signal. It does not set any of the other timings. In addition, it uses the bcm_host_get_peripheral_address() function to get the correct peripheral address for the PI device it’s running on. So, it should work for you. If it does work, let me know and I’ll add that it’s been tested on the PI 3B+ w/PAL.
    3. In the pic of the Apple IIc monitor above, the PI 4 was set to 720×224 resolution with the VGA 8×8 font. I’ve also tested it with a cheap old RCA 5″ NTSC black and white TV and it’s actually legible. It’s tiny and a little hard to see, but the resolution of the CRT is not the problem. Monochrome CRTs have high resolution than their color counterparts.
      If you are just using the Linux console (PI OS Lite), I would suggest starting with 640×192 resolution using the VGA 8×8 font. If that’s readable, bump up the resolution from the there until it’s too small for your liking. Trying to use an old NTSC or PAL TV to display the X/Wayland GUI, will be disappointing. You can’t get enough resolution to fit everything reasonably on the screen.
