Tiny RC Four-Wheeler Gets Chassis Upgrade For More Traction
[Azpaca] purchased a fun little toy car from Tamiya, only… there was a problem. The little off-roader wasn’t up to scratch—despite its four-wheel-drive, it couldn’t get over rough ground to save its life. Thus, it was time to 3D-print a better chassis that could actually get through it!
The problem was quite obvious. With no suspension and a rigid chassis, the vehicle would tend to end up with one or more wheels on the air on rough surfaces. To rectify this, [Azpaca] created a twisting chassis which would allow the wheels to better remain in contact with the ground. The design is relatively straightforward, and reuses much of the original drivetrain, including the simple brushed motor. However, with a pivot right behind the front wheels, it has much more traction on rocks and gravel, and can traverse these terrains much more easily.
Tamiya’s motorized toys aren’t particularly well known in the West, but it’s neat to see the community that exists around modifying them around the world. Design files are available for the curious. If you’re not down with mods, perhaps you’d prefer to print your own cars from scratch. Video after the break.
9 thoughts on “Tiny RC Four-Wheeler Gets Chassis Upgrade For More Traction”
  1. Nice work. But music choice for video is horrible there are some weird anime noises that make it hard to listen because interfering with talking.
    1. What you are hearing are not “strange anime noises”, it’s the original Japanese speech that sometimes peaks through the automatically translated soundtrack. If you go in the Youtube settings you can select the original track, though to be fair that too appears to be computer generated, and uses a childish voice.
  2. Nice video, but NiCd batteries? I thought we weren’t using them any more? I knew the Tamiya brand from r/c model airplane gear. Doesn’t look like this car is r/c, but I would think the same idea could be used on an r/c version.
    1. Ni-Cd still see some use in Mini 4WD racing. Which this little crawler design is an offshoot of, and why it originally had a rigid chassis for racing on a track.
      NeoChamp makes probably the most popular NiMH cells for mini 4WD. So probably worth considering for people who don’t still have a bunch of nicads around from the hobby.
  3. I don’t know if it’s my YouTube settings or what but this new English voiceover is horrible. I like hearing the Japanese
  4. Just because you don’t now that company in the US doesn’t mean it’s not known in the West. It’s highly popular in Europe let alone in Germany.
