When Is An Apple Laptop Not A Macbook? When It’s An Apple II
Do you remember, some years ago, when that brand-new 8086-based laptop hit the shelves? Great for PC lovers, but not so fun for those on the fruitier side of the street. Well, the same Chinese firm that brought us the Book8086 are back, this time with an ‘Apple’ Laptop that is decidedly not a MacBook– the Book II is a dual-processor Apple II clone in a laptop form factor.
… but just look at all those DIPs on the inside. Authentically retro!
Dual processor? On an Apple II? It wasn’t that uncommon, back in the day — that’s what the Z80 softcard was, after all: a second processor that let you run CP/M and associated business applications, and this one has it built-in. It also has the 80-column video card, a second floppy controller, a printer interface, and a 16 kB ROM card for languages. That leaves two of the Apple’s expansion slots available, one of which is broken out externally on the back of the laptop, along with the printer and floppy ports.
Useful? Probably no more so than the NEC V20-based PC version. Still, those did find buyers and we have no doubt that this new laptop will, too. Especially since with the right expansion card, you might get this machine running DOS as well. Of course if you don’t feel like shelling out the quid or running an emulator, you can always roll your own Apple II on an FPGA.
Thanks to [Stephen Walters] for the tip! We usually steer clear of product announcements like this, but [Stephen] figured we’d be interested in this one since we covered the then-new retro PC versions way back in 2023.
24 thoughts on “When Is An Apple Laptop Not A Macbook? When It’s An Apple II”
  1. Btw, in case someone wonders..
    In the 80s, both IBM PC and Apple II were well established PC platforms.
    There were models of same looking computers that were PC and Apple II.
    Such as Vtech Laser 128 and Vtech Laser XT.
    There also were hybrid PCs with 6502 and 8088 CPU that could run both Apple DOS and MS-DOS!
    Such as Cordata WPC Bridge or the Gigatronics KAT.
    Review Vtech Laser 128/XT
    https://www.youtube.com/watch?v=GZX7tjnb9sE
    Gigatronics KAT
    https://www.youtube.com/watch?v=Zhu9vxEm8Gc
    Cordata WPC Bridge
    https://forums.atariage.com/topic/282743-this-thing-is-pretty-cool-apple-iie-and-ibm-pc-in-one/
      1. That’s a good question, really. I don’t understand the success of the C64, either.
        My father completely missed the C64’s existance during the 80s, for example.
        His world were Z80 computers and IBM PCs. He knew the Apple II, though.
        As the article hints, the Apple II not seldomly had an Z80 card installed (Microsoft SoftCard or similar).
        It was a notable CP/M platform, thus, rather than “just” being another insignificant 6502 toy computer.
        If I had to guess, then perhaps C64 was popular because of games and kids doing piracy at school yard on a large scale.
      2. The topic of missing C64 clones is very interesting, really.
        I mean, both ZX Spectrum and ZX81 had numerous clones despite them having custom chips such as ULA.
        I guess the C64 was too cheap for being cloned by other manufacturers. So they didn’t bother.
        On otherhand, that explanation is a bit too simple minded.
        The C64 had a large software library and in former eastern block a C64 wasn’t easily accessible.
        That’s why many ZX Spectrum clones and Apple II clones were made over there.
        Also, the C64 had a Kernal in ROM, along with a BASIC interpreter.
        So there was some hardware abstraction, at least.
        A limited C64 clone or C64 compatible was certainly possible by porting the C64 Kernal to a different platform and changing port addresses pointers in memory.
        Which would at least have worked fine for text adventures and productivity software.
      3. The VIC II chip for grapics was essentially a 12 bit GPU, with quite high integration for its time. Even today there are no notable clones. Whereas other chips of the C64 have been cloned in FPGA or similar over the time.
        I think the amount of chips in the C64 that were custom silicon was a key stopping point for cloning.
          1. The SID was used on other platforms, too. Such as IBM PC or C128.
            I wonder if the VIC II could have had been ordered by MOS as an individual part.
      4. It was the lowest price for the base computer by far.
        An apple2e ran about $1500, the ibm pc 5150 (XT class) had the same base price of $1500 but no storage or ram, so actually ran twice that at $3k
        The c64 went from $600 down to $200 between 1980 and 85
        And I’m not slamming it as cheap, it was still very capable.
        Base system could use audio tapes for storage the same as the apple2, so an expensive floppy wasn’t required like on the PC.
        As for cloning, at least two ICs were custom MOS chips, MOS being the chip fab they bought.
        For about 40 years we still didn’t have the SID or VIC chips replicated.
        Those only started being cloned in the last few years and even at that the SID is a “best effort” reproduction. The original IC design files are gone.
        Compare that to the PC or Apple2 – Every last chip in those except the mask roms you could buy off the shelf. There were other roms (eprom and such) you could adapt and those were also off the shelf. You only had to copy the data.
      5. Commodore owned MOS and made their own chips. Since there weren’t second sources for them, like an 8086 or Z80, you’d have to get the whole chipset from Commodore. Or just buy the computer which’d likely cost less.
    1. It was – as an Apple 2c. You needed a CRT and a floppy drive to use it. If this new clone costs $500ish now, why not buy a vintage 2c for around the same money?
      1. There was a snap-on lcd for the 2c. Not a good one, but they made and sold it.
        The 2c also had a floppy drive built in.
        Although I didn’t know this as a kid, the power brick for the 2c put out ~15v, but the actual regulated power supply was internal to the 2c. You can feed it 12v from a car lighter port.
        You’re still tethered for power but it was far more portable than most people think.
  2. There was also a card called “The Mill” IIRC. It had a 68008.
    I wonder about all those RAM. Is dynamic RAM required for the video generation? You can get single chip 64Kx8 150ns RAM quite cheaply. I have thought about putting one, + a decoding GAL if needed on a card for an Apple II slot and pulling the ram chips to reduce heat.
    1. If it’s like their other designs it’s copied from somewhere. In the 386 there’s a weird choice for memory that makes sense if you’re using the template from something like the original ALi reference where it was the cheap option for the target use case of the time.
      There’s something to be said for going with a design that works. Looks like lots of real-estate in this case, though.
