Pi Day is here! We bet that you know that famous constant to a few decimal points, and you could probably explain what it really means: the ratio of a circle’s circumference to its diameter. But what about the constant e? Sure, you might know it is a transcendental number around 2.72 or so. You probably know it is the base used for natural logarithms. But what does it mean?
The poor number probably needed a better agent. After all, pi is a fun name, easy to remember, with a distinctive Greek letter and lots of pun potential. On the other hand, e is just a letter. Sometimes it is known as Euler’s number, but Leonhard Euler was so prolific that there is also Euler’s constant and a set of Euler numbers, none of which are the same thing. Sometimes, you hear it called Napier’s constant, and it is known that Jacob Bernoulli discovered the number, too. So, even the history of this number is confusing.
But back to math, the number e is the base rate of growth for any continually growing process. That didn’t help? Well, consider that many things grow or decay through growth. For example, a bacteria culture might double every 72 hours. Or a radioactive sample might decay a certain amount per century.
Classic
The classic example is compound interest. Suppose you have $100, and you put it in the bank for a 10% per year return (please tell us where we can find that, by the way). So at the end of the year, we have $110, right? But what if you compound it every six months?
To figure that out, you look at the $100 after six months. The annual interest on the money is still $10, but we are only at 6 months, so prorated, that $5. Therefore, after six months, we have $105. At the end of the year, we look at the 10% of $105 ($10.50). That’s still for a year, so we need to halve it ($5.25) and add it in ($105+105.25=110.25). So, compounding every six months means we get an extra quarter compared to simple interest.
What if it was compounded monthly? Now, we divide our interest by 12, but we have a little more money every month. After the first month, we have $100.83 ($100.00 + 10/12). The second month’s net is $101.67. By the end of the year, you have $110.47. Not quite twice as much extra as you had before.
So what if you could compound weekly? Or daily? Or hourly? Generally, you’ll get more, at least up to a point. Eventually, the interest will be split up so much that it will balance the increase and, at that point, you won’t make any more. There is an upper limit to how much money we can have at the end of the year at 10%, no matter how often you compound the interest.
So Where’s e?
Assume you could get a 100% return on your money (definitely let us know how to do that). That means if you go for a year, that’s a return of 2 — you double your money. But if you split the year in half and compound, you get 2.25 times the original amount. You can try a few more splits, and you’ll find the equation for growth is (1+1/n)n. That is, if you only compute it once (n=1), you get double (1+1). If you compute interest twice, you get 2.25 (that is, (1+1/2)2).
If you set n to 1,000, the return will be 2.7169. That’s even better than 2.25. So 100,000 should be wildly better, right? Not so much. At 100,000 you get a 2.71814 return. At 10,000,000 the rate is 2.71828 (or so).
Look at those numbers. Going from 1,000 to 10,000,000 only increases yield by about 0.001. If you know calculus, you might know how to take the limit of the growth equation. If not, you can still see it is going to top off at around 2.718. Those are the first digits of e.
Of course, e is like pi — transcendental — so you can’t ever get all the digits. You just keep getting closer and closer to the actual value. But 2.718 is pretty close for practical purposes.
Scaling
We can scale e to whatever problem we have at hand. We just have to be mindful of the starting amount, the rate, and what a time period means. For example, to work with our 10% rate (instead of 100%) we have to consider the rate e0.10 or about 1.105. Then, to scale for amounts, we have to multiply by the rate. So remember our $100 at 10% example? Our maximum return is 100 x 1.105 = 110.50. Why did we only get $110.47? Because we compounded 12 times. The $110.50 result is the maximum.
More Years
You can also multiply the rate by the number of periods. So if we left the money in for five years: 100 x e(0.10 x 5). If you think about it, then, making 50% for one year has the same maximum as making 10% for 5 years (or 25% for 2 years).
Negative Growth?
Suppose you have 120 grams of some radioactive material that decays at a rate of 50% per year. How much will be left after three years? Simplistically, it seems like the answer is that it will be depleted after two years. But that’s not true.
Just as compounding adds more money, a decay rate removes some of the radioactive material, meaning the absolute decay rate gets slower and slower with time because it is a percentage of the radioactive material’s mass.
Just for the sake of an example, suppose at some imaginary small period, the sample is at 100 grams and, thus, the decay rate is 50 grams/year. Later, the sample is at 80 grams. The decay rate is 40 grams/year, so it will take longer to go from 80 to 60 than it did to go from 100 to 80.
In this case, the rate is negative, so the formula will be 120 x e(-0.5 x 3). That means you will have about 26.8 grams of radioactive material left in three years.
Modeling
Consider the classic equation for an RC circuit: Vc=Vs(1-e(-t/(RC))). Here, Vc is the capacitor voltage, Vs is the supply voltage, t is in seconds, and RC is the product of the resistance in ohms and the capacitance in farads.
What can we infer from this? Well, you could also write this as: Vc=Vs-Vs x e(-t/(RC)). Looking at our earlier model for money, it is plain that Vs is the voltage we start with, t is the time, and rate is -1/RC (time can’t be negative, after all). That makes sense because RC is the time constant in seconds, so 1/RC is the rate per second. The formula tells us how much voltage is charged in the capacitor, and subtracting that from Vs gives us the voltage drop across the capacitor.
Think about this circuit:
At t=0, we have Vs(1-e0), which is 0. At t=0.5, the voltage should be about 7.86V; at t=1, it should be up to 10.57V. As you can see, the simulation matches the math well enough.
Discharging is nearly the same: Vc=V0 x e(-t/(RC)). Obviously, V0 is the voltage you started with and, again -1/RC is the rate.
So Now You Know!
There’s a common rule of thumb that after a time period (RC) a capacitor will charge to about 63% or discharge to about 37%. Now that you know the math, you can see that e-1=0.37 and 1-e-1=0.63. If you want to do the actual math, you can always set up a spreadsheet.
Anything that grows or shrinks exponentially is a candidate for using an equation involving e. That’s why it is a common base for logarithms. Of course, most slide rules use logarithms, but not all of them do.
(Title image showing e living in pi’s shadow adapted from “Pi” by [Taso Katsionis] via Unsplash.)
I just finished a book on the story of e. Fascinating how even used in general and then on to e with complex numbers like Euler’s e^i*Ď€+1=0 to tie the fundamental constants together.
this is all dancing around one of the most remarkable chapters ever written on math, from the feynman lectures:
https://www.feynmanlectures.caltech.edu/I_22.html
in about a dozen pages he covers all of algebra starting at kindergarten math, for the purpose of reaching the crown jewel, the euler identity. which is truly a surprising piece imo. sin/cos/e all belong to algebra! trigonometry doesn’t even exist.
it takes a couple hours to really sit down and read it even though it’s short but i recommend it
Thank you for reminding me of one of my favourite people. I’m off to read that chapter. I bought the lectures (the large red paperbacks) back in graduate school and now I have no idea/recollection of what happened to them.
Isn’t it wild to think he’s never written a book?
Surely, You Must Be Joking, Mr Feynman?
Perhaps its the language or the way its stated, i would not consider this starting at kindergarten, especially considering he assumes you know what integers are without defining them.
**WARNING!!!*** This site contains virus trojan. Firefox warns when you visit:
What? dude, it’s caltech
I love Feynman. Out of curiosity, does this involve the standard proof of Euler’s formula, using Taylor series? It’d be easy enough to imagine how to get to sin / cos / e^x without trig, since complex numbers are the natural number system following algebraic reasoning and complex exponential functions are smooth periodic functions and smooth periodic functions beget sin functions, but if you know your Taylor series, proving Euler’s formula is incredibly simplistic and then Euler’s identity follows from a simple evaluation of the formula.
Knowing Feynman it does something ingenuously different and involves building it from the ground up to get to Euler’s formula, and I’d probably love to read it, but finite time in the day to post nonsense on the internet leaves me with little time to read things, particularly if I’m already familiar with it.
Can you report a comment for sucking?
Too many words for you?
Of course financial interest rate math, and nuclear radioactive decay rate math, is so similar. Both can be detrimental to your health.
This is why I often wish I’d been taught the way I see it now: Start with the Unit Circle.
Fabozzi’s Fixed Income Instruments is a wonderful book for the Excel set. I celebrate that too!
The radioactivity example is incorrect. For 120 grams that decays at 50%/year, after 3 years the remaining radioactive mass is 120 x 0.5 x 0.5 x 0.5 = 15 grams.
The decay rate changes every year as the activity reduces, thus the negative exponential rate, relative to the e. It does not halve every year, perhaps only on first year in this example… The second and third half life are much longer than one year.
I am sorry, you are right. I think, the example was written poorly, the decay constant in the equation is wrong. Ithink it should not be 0,5 but 0,6931…
Because people like digits, e is particularly easy to remember:
2.7
18 28
18 28
45 90 45
little typo:
105 + 5.25 = 110.25
I like starting with the question “Is there a non-trivial function whose derivative is itself, and if so, what is that function?”
Yes, there is, and that function is e^x (technically c*e^x)! It’s a very, very good mathematical question, in that you can start from the definition of f(x) = f'(x) and then reason out the whole process, from determining that it must be an exponential function to determining what the specific base of the exponential function is.
Most people will read this as the sample having a half-time of 1 year, in which case you’d have 15g not 26.8g left after three years. No e required for that one.
To get to 26.8g you need a “decay constant” of 0.5, ie. a “mean lifetime” of 2 years (the half-life or “median lifetime” in this case would be ln(2)/.5 or ~1.386 years).
A “material that decays at a rate of 50% per year” but which leaves you with 39.3% decayed after a year makes no sense.
Not sure how best to convey a 50% “decay constant” unambiguously in text though…maybe “a sample which initially emits radiation at a rate which if had continued unchanged for a year would have meant 50% of the material had decayed” or something like that…? There’s a reason the more intuitive half-life is more commonly used.
(most definitions of “decay constant” you find on the internet seem to be wrong too .. it’s definitely not “The probability that an individual nucleus will decay per unit of time” for example – if it was then a .5 decay constant would decay half the atoms in that unit of time..which it doesn’t)
Now try to wrap your head around i…
“Imaginary numbers are real” by Welch Labs on YT.
Hallucinations by Wolfram.
Very interesting reads overall. But my favorite constant number is [phi], or 1.618 033 897 499. I have used this in some of my furniture making, and I only use the first 6 place after the decimal. A planned build for an entertainment console is 40″ (~102 cm) tall and (40″ x [phi]) 65.25″ (~164 cm) wide. Then my 80’s stereo will have a home.
I considered talking about phi, but this was already long enough. Maybe next year!
Yes, we can discuss this for a future article on Hackaday As we do know: it is a rational number based on the Fibonacci sequence, and has a couple of interesting properties.
Phi is really cool, even if a lot of the “it’s everywhere in nature” stuff is rather nonsense. What’s awesome about phi is its continued fraction expansion, and how that shows it’s the least approximable irrational number. Pi, on the other hand, is highly approximable, and this is seen easily in its continued fraction expansion, as you get a large value very early on. This is what allows 355/113 to work well, for example. Phi, on the other hand, is just 1s all the way down.
Can’t believe they used E instead of e in the headline.
Right? I’ll go fix it.
