3D Printed Brick Layers For Everyone
Some slicers have introduced brick layers, and more slicers plan to add them. Until that happens, you can use this new script from [Geek Detour] to get brick layer goodness on Prusa, Orca, and Bambu slicers. Check out the video below for more details.
The idea behind brick layers is that outer walls can be stronger if they are staggered vertically so each layer interlocks with the layer below it. The pattern resembles a series of interlocking bricks and can drastically increase strength. Apparently, using the script breaks the canceling object functionality in some printers, but that’s a small price to pay. Multi-material isn’t an option either, but — typically — you’ll want to use the technique on functional parts, which you probably aren’t printing in colors. Also, the Arachne algorithm option only works reliably on Prusa slicer, so far.
The video covers a lot of detail on how hard it was to do this in an external script, and we are impressed. It should be easier to write inside the slicer since it already has to figure out much of the geometry that this script has to figure out by observation.
If you want more information, we’ve covered brick layers (and the controversy around them) back in November. Of course, scripts that add functions to slicers, tend to get outdated once the slicers catch up.
18 thoughts on “3D Printed Brick Layers For Everyone
    1. Also you can have plugin API that allows extremely convenient implementation of patented technology. Maybe even very flexible configuration interface, that allows to achieve copyrighted logic which just tiny bit of user creativity.
      1. Not a lawyer, but isn’t it usually the case that something as generic as layering 3d prints like we’ve been layering bricks for hundreds/thousands of years would only be protected in relation to the specific algorithm used to generate the gcode. This is how android phones can have very similar scrolling snapback behavior to apple phones because they both use a different algorithm (though this had to be tested in court first obviously).
    2. This is non-trivial part of the law, that varies from jurisdiction to jurisdiction, and how different jurisdictions’ patents interact.
      In the USA,to a reasonable approximation, ANY use of US patented IP is prohibited without authorization, even personal use.
      In some other jurisdictions, personal use may be ok.
      In others, non-commercial may be ok.
      It gets interesting with IP patented in a different jurisdiction, such as using IP protected in the US for a product in the EU.
      The details are why I know patent lawyers.
    3. Just a reminder that all the conversation about legally protected use is an intellectual exercise. If a patent holder pursues you in court, you still have to show up with a lawyer. If you intend to defend your position, it’s going to cost you time and money and regardless of how right you feel you are, you still might walk away unsuccessful.
      And rights holders know this.
    4. Sure, you’re allowed to code it yourself for your own personal use, just as you’re allowed to copy a patented item and use it non-commercially. Distribution, whether it’s physical or code, whether you sell or offer it for free, is another matter.
  1. The patent should be overturned. Someone just needs to file the paperwork for review with the uspto. Stratasys wrongly claimed this again from a patent that is already expired. They also included the incorrect reference to the prior art and the uspto missed it. This is public domain already.
    1. “someone just needs to” thanks for volunteering!
      But seriously, the USPTO won’t do anything. They’re the ones blindly approving the bad patents in the first place – it’s not a bug, it’s a deliberate feature.
  2. Thanks for sharing the Script, for talking about Brick Layers again – and the Patents
    Since CNC Kitchen made his video, Brick Layers became some sort of obsession of mine – specially after I found out about the 2020’s Patents. I had to research them… and I got in disbelief when I found the original 1995 Stratasys (expired) patents. That’s when this journey got serious – and making the Script raised the bar to ‘craziness’ level.
    The new Patents are having a hard time – as they should. The European application has been challenged and very likely won’t be granted. The 3rd continuation of the USA patent is also being challenged – so far, the community didn’t need to spend a dime.
  3. Stratasys’s current Patent is likely invalid in the way it may or may not have been filed, per another hackaday post I read a bit ago. The original patent has expired for brick style layering of FDM prints and they filed for a new patent for essentially the same exact parameters but the patent numbers or something of sorts didn’t match like they should have to be valid. It appears they are trying to essentially renew the patent by resubmitting the same patent with some changes which is questionable imo.
    I think it should be free game, good for us, I’ll give it a go!
Leave a Reply to Geek Detour - EversonCancel reply
