DIY Split Keyboard Made With A Saw
Split keyboards are becoming more popular, but because they’re still relatively niche, they can be rather expensive if you want to buy one. So why not make your own? Sure, you could assemble one from a kit, but why not take a cheap mechanical keyboard, slice it in half and just waves hands connect the two halves back together? If this thought appeals to you, then [nomolk]’s literal hackjob video should not be ignored. Make sure to enable English subtitles for the Japanese-language video.
Easy split keyboard tip: just reconnect both halves... (Credit: nomolk, YouTube)
Easy split keyboard tip: just reconnect both halves… (Credit: nomolk, YouTube)
In it, the fancy (but cheap) mechanical keyboard with Full RGB™ functionality is purchased and tested prior to meeting its demise. Although the left side with the cable and controller still works, the right side now needs to be connected, which is where a lot of tedious wires have to be soldered to repair traces.
Naturally this will go wrong, so it’s important to take a (sushi) break and admire the sunset before hurling oneself at the tracing of faulty wiring. This process and the keyboard matrix is further detailed on the blog entry (in Japanese) for this process.
Although this was perhaps easier than the other split keyboard project involving a membrane keyboard, this tongue-in-cheek project demonstrates the limits of practicality with this approach even if it could be cleaned up more with fancier wiring.
We give it full points for going the whole way, however, and making the keyboard work again in the end.
23 thoughts on “DIY Split Keyboard Made With A Saw
    1. If the two keyboards already had controllers on the opposite sides, it would be easier.
      Otherwise, it would be more work. As mentioned, the keys are connected in a matrix (grid) of horizontal and vertical wires, the ends of which connect to the controller. The work involves figuring out the matrix and reconnecting it.
    1. There is nothing special about Japanese saws, except they cut on the pull instead of on the push stroke.
      I am a (fine)woodworker-in-training and there is about a 50-50 split in class as who likes them. I personally don’t like them, I prefer a European style push saw and have just done some very fine cabinetry with an ordinary universal/panel saw (a basic construction saw, cheapest from home depot). No saw cut is fine enough for a glue job or sight work, so you always need to use some smoothing (in this case, an ordinary hand plane) after hand sawing, Japanese or not.
      But if you want one, they are not that expensive. Basic models are about €25 (similar in USD). Expensive models have the extra quality of being overpriced, which for some people might be a valuable asset.
        1. I was talking about manual saws. I find that with manual sawing, the resulting surface (tape won’t help with that) is never smooth enough for a glue job. With a good radial or table saw blade it usually is.
          1. ?
            I’m no expert with using saws, and have a quite cheap one of these pull saws and was surprised at how I couldn’t tell the difference between the shop cut sides and my hand cut end. This was not with some rough timber….
  1. Cable on the left, all I’ve seen are on the right. Find one of those and cut off half and half each and plug in both to USB. A scissors is all you’d need to cut the membranes, hopefully with no dead areas. Could cut neat or savage to the plastic case.
  2. Heh, this is even worse than my tenkeyless hackjob for a Model M keyboard.
    (I removed the keys, cut the plastic part, then dremeled apart the metal base, masked the edges with tape and folded the membrane back over. The outter shell was cut (slightly offset) so that the base retained the foot and the top retained the inset edge. While being at it I addeed a QMK based avr something for USB connetivity)
Leave a Reply to erffrfezCancel reply
