Hackaday Links: April 27, 2025
Hackaday Links Column Banner
Looks like the Simpsons had it right again, now that an Australian radio station has been caught using an AI-generated DJ for their midday slot. Station CADA, a Sydney-based broadcaster that’s part of the Australian Radio Network, revealed that “Workdays with Thy” isn’t actually hosted by a person; rather, “Thy” is a generative AI text-to-speech system that has been on the air since November. An actual employee of the ARN finance department was used for Thy’s voice model and her headshot, which adds a bit to the creepy factor.
The discovery that they’ve been listening to a bot for months apparently has Thy’s fans in an uproar, although we suspect that the media doing the reporting is probably more exercised about this than the general public. Radio stations have used robo-jocks for the midday slot for ages, albeit using actual human DJs to record patter to play between tunes and commercials. Anyone paying attention over the last few years probably shouldn’t be surprised by this development, and we suspect similar disclosures will be forthcoming across the industry now that the cat’s out of the bag.
Also from the world of robotics, albeit the hardware kind, is this excellent essay from Brian Potter over at Construction Physics about the sad state of manual dexterity in humanoid robots. The whole article is worth reading, not least for the link to a rogue’s gallery of the current crop of humanoid robots, but briefly, the essay contends that while humanoid robots do a pretty good job of navigating in the world, their ability to do even the simplest tasks is somewhat wanting.
Brian’s example of unwrapping and applying a Band-Aid, a task that any toddler can handle, as being unimaginably difficult for any current robot to handle is quite apt. He attributes the gap in abilities between gross movements and fine motor control partly to hardware and partly to software. We think the blame skews more to the hardware side; while the legs and torso of the typical humanoid robot offer a lot of real estate for powerful actuators, squeezing that much equipment into a hand approximately the size of a human’s is a tall order. These problems will likely be overcome, of course, and when they do, Brian’s helpful list of “Dexterity Evals” or something similar will act as a sort of Turing test for robot dexterity. Although the day a humanoid robot can start a new roll of toilet paper without tearing the first sheet is the day we head for the woods.
We recently did a story on the use of nitrogen-vacancy diamonds as magnetic sensors, which we found really exciting because it’s about the simplest way we’ve seen to play with quantum physics at home. After that story ran, eagle-eyed reader Kealan noticed that Brian over at the “Real Engineering” channel on YouTube had recently run a video on anti-submarine warfare, which includes the uses of similar quantum magnetometers to detect submarines. The magnetometers in the video are based on the Zeeman effect and use laser-pumped helium atoms to detect tiny variations in the Earth’s magnetic field due to large ferrous objects like submarines. Pretty cool video; check it out.
And finally, if you have the slightest interest in civil engineering you’ve got to check out Animagraff’s recent 3D tour of the insides of Hoover Dam. If you thought a dam was just a big, boring block of concrete dumped in the middle of a river, think again. The video is incredibly detailed and starts with accurate 3D models of Black Canyon before the dam was built. Every single detail of the dam is shown, with the “X-ray views” of the dam with the surrounding rock taken away being our favorite bit — reminds us a bit of the book Underground by David Macaulay. But at the end of the day, it’s the enormity of Hoover Dam that really comes across in this video. The way that the structure dwarfs the human-for-scale included in almost every sequence is hard to express — megalophobics, beware. We were also floored by just how much machinery is buried in all that concrete. Sure, we knew about the generators, but the gates on the intake towers and the way the spillways work were news to us. Highly recommended.
14 thoughts on “Hackaday Links: April 27, 2025
    1. A lot of people use “enormity” instead of “enormousness” because they sound kind of similar and because when used correctly “enormity” is most often used with a noun that tells you about the badness of the whatever leaving “enormity” as a scaling adjective.
      1. The enormity of the enormity situation is such that enormity is now also a synonym for enormousness. I suppose people like it because it’s easier to type and spell.
  1. the AI generated DJ is interesting, especially reading through the comments on the linked article. on one hand, how many of us really care, as long as something keeps playing music? probably far fewer than the current accepted radio personality standards.
    but then the comments decry about how it’s stealing work from a real person, and to give a real person the job. though realistically, they likely moved to this route because it was such a difficult position to staff for a variety of reasons, internal or external.
    but then the question becomes, if the job is so easily replaced by AI, but the only reason not to is because real people want the job, aren’t we just “government-cheese”ing our way into a false job economy?
    1. It’s not like it’s anything new. There was a radio station where the DJ died and they just kept playing his previously recorded stuff.
      Everyone knew, and no-one cared.
      Who listens to radio anyway?
  2. “unwrapping and applying a Band-Aid, a task that any toddler can handle” – plenty of toddlers can’t do this, at least not well and consistently. That said, the point is taken: Immature humans 1, robots 0 when it comes to applying a Band-Aid.
  3. A couple of months ago they started using AI in an obscure local Polish radio station, fired some journalists and not only they didn’t hide it, they boasted about it. It wasn’t easy to find a proper article in English, so maybe that’s why it wasn’t well known abroad. Here’s something that maybe isn’t 100% accurate, but at least doesn’t require Google translate: https://notesfrompoland.com/2024/10/28/polish-broadcaster-shuts-down-ai-run-radio-station-after-a-week-following-backlash/
  4. AI DJ? hmm, I’m thinking of another story plot for something like “The Last of Us” or ?? Someone trying to get to whoever the voice is, that’s still broadcasting spuratically. But turns out to be a someones Hackaday(?) project for collecting a bit of solar energy or a hot roof & peltier etc, and kicking off a broadcast whenever the needed power has been accumulated for maybe an hour or 2 of run time.
  5. we suspect that the media doing the reporting is probably more [exercised] about this than the general public
    Did you mean [excited]?
    The muscles that control human hands are mostly located in the human’s arms. I don’t think it’s the mechanical aspects of making a hand that are the biggest challenge (though it sure isn’t easy). I think that achieving the sensing and feedback is what’s lacking. But I think another issue is that robots are generally built for specific tasks; building something as general-purpose as human hands would be way overbuilt (and costly) compared to something special purpose.
    I wonder if it will require the development of “motors” that function just like human muscles before we can build general-purpose “hands” (and other human-like parts) easily and affordably?
    1. Well, that’s a quoting fail. I suppose I needed to insert more blank lines to make it work correctly. Let’s test that:
      this looks like a quote
      and this isn’t
      but this also looks like a quote
      and so it goes.
Leave a Reply to CityZenCancel reply
