We love Arduino here at Hackaday; they’ve probably done more to make embedded programming accessible to more people than anything else in the history of the field. One thing the Arduino ecosystem is rarely praised for is its speed. That’s where [Playduino]Â comes in, with his video (embedded below) that promises to make everyone’s favourite microcontroller run 50x faster.
You might be expecting an unstable overclocking setup, with swapped crystals, tweaked voltages and a hefty heat sink, but no! This is stock hardware. The 50x speedup comes from one simple hack: don’t use digitalWrite();
If you aren’t familiar, the digitalWrite() function is one of the key functions Arduino gives you to operate its boards– specify the pin and the value (high or low) to drive it. It’s very easy, but it’s also very slow. [Playduino] takes a moment to show just how much is going on under the hood when you call digitalWrite(), and shows you what you can do instead if you have a need for speed. (Hint: there’s no Arduino-provided code involved; hardware registers and the __asm keyword show up.)
If you learned embedded programming in an earlier era, this will probably seem glaringly obvious. If you, like so many of us, got started inside of the Arduino ecosystem, these closer-to-the-metal programming techniques could prove useful tools in your quiver. Big thanks to [Stephan Walters] for the tip.
Of course if you prefer to speed things up by hardware rather than software, you can overclock an Arduino– with liquid nitrogen, even.
Perhaps this is a dumb question but why can’t things like DigitalWrite be remade so they aren’t as slow and compile down to the same fast ASM as manually doing it?
It can! The Teensy implementation of digitWrite is extremely fast. You can also use the digitalWriteFast library
Sure… just use digitalWriteFast()
The limitation is that the pin ID must be a constant. Not usually a significant limitation.
Welcom to the world of HAL. If you try to be a be all and do all, you will be forever taxed.
Is this 2009 again? (Actually I wish it was.)
Everyone and his dog knows
digitalWrite()is multiplatform but terribly slow because of all the safety checks and multiplatforming.Leveraging templates and constexpr to achieve cross platform compatibility would probably improve speed without sacrificing safety.
Indeed, but the italian students who wrote the function 15+ years ago thought it was a good idea to check if a pin is used for PWM, ADC, or whatever and then fail to write if one of those other functions is active. It’s mind boggling weird decision.
Other gripes I have with “arduino” is that it’s not a good learning platform at all. It’s very sloppy written code, a mishmash of C and C++ (which they try to hide and give it some other name), and they invite you to learn the same sloppy methods. By default they also (used to?) hide the compiler error messages.
String functions also have slightly different names and functionality from standard functions.
I understand starting the first blinking led with a delay_us() function, but in the same chapter it should be explained why writing code in that fashion is a very bad idea that will get you into trouble later. And the silly init() and loop() functions both make it harder to find out where the program starts (I’m always searching for main(). What’s simpler then main() ).
But still, I guess it’s an improvement over BASIC.
Huh? If PWM is on, digitalWrite turns it off.
Er, the compiler should check that, not the code at runtime.
I don’t use Arduino IDE much, but that’s my thoughts exactly.
And even if it is in runtime, does the “verifications” -whatever they may be- repeat EVERY invocation of digitalWrite ()…?
If your target is a 328 -or any other device-, simple rewrite/use a two line inline function/macro, manipulating registers directly. I think if you really are into embedded, it’s the simple and obvious next step for everyone.
That’s the thing though, it may be known by people who are immersed in the Arduino ecosystem but far from everyone eats, sleeps and dreams Arduino (some of us prefer tools with proper debugging that don’t break with every .0.0 revision for example) and this is one of those nuggets of knowledge that would only become apparent if your application needed to eke out every processor cycle for performance.
Then you should really be asking yourself if you’re in the right development environment.
Congratulations! A lucky one-of-ten-thousand case…
https://xkcd.com/1053/
Again, a fix for the Arduino playpen. Arduino is excellent at what it does. Provide a suite of tools for learners and a platform for quick development for non-performance-critical applications.
Hacks like this show why it is a starting point, not an end. I see it now: Next up, a hack to allow decent event driven behaviour, then a hack to allow for decent use of timers, and then…. you are no longer in the Arduino world, but have moved to genuine embedded programming, though hopefully with a decent RTOS. Which Arduino is not. Nor does it pretend to be.
What does the Arduino documentation have to say about direct port manipulation?
“Generally speaking, doing this sort of thing is not a good idea”
Yup. You CAN do it, but really are taking a risk of a collision in resource allocation or ending up with an inconsistent state between reality and the Arduino environment. It also violates the precept that the environment is hardware agnostic from the point of view of the programmer, and portability is out the window.
A good RTOS does a MUCH better job at abstracting these things, but requires more capable hardware than Arduino will run on at the minimum.
An RTOS doesn’t really provide hardware access. That’s what the HAL is for.
FreeRTOS isn’t going to help with GPIO
When you need to get more speed out of the Arduino, just stop using the Arduino libraries. It’s not just digitalWrite that’s slow. The ATmega microcontrollers are very easy to program. The peripherals are fairly simple and the datasheet is only a few hundred pages long.
This. Arduinos did just as much damage as they did good. They abstracted the hardware to the point you have to hack your way to talk to it directly. Talking to and manipulating the hardware is what embedded programming is all about. Knowing the hardware is essential. The most damage they did was flood the market with people calling themselves embedded programmers when they can’t even bring up a system from power on with code or set up a basic main loop.
“Talking to and manipulating the hardware is what embedded programming is all about. ”
We already had this before with PIC16C84 and PIC16F84/A, you maybe remember that chip.
Most projects of the time provided a HEX file only, or an ASM file. PICBasic wasn’t always being used.
So at end of day you had to learn PIC16F84 ASM, which was specific for the chip.
Other PICs had different assembly language.
“The most damage they did was flood the market with people calling themselves embedded programmers when they can’t even bring up a system from power on with code or set up a basic main loop.”
Ah yes, the “real men” throphe.. :)
By that logic, only C/C++ programmers are real programmers.
As a former VB6 progra.. err, VB6 user, I’m used to such statements.
Funnily, the “badly coded” applications did run as wished.
While the professionally written applications not seldomly were ugly and not user-friendly. :D
No its just fundamentals. Hardware costs money. If you uprate hardware to simplify programming you are wasting money.
/20 years of embedded programming including boot roms and porting linux to custom hardware. One system flew on commercial rockets.
There is an implied hardware production volume in your thinking.
If you only need one, and weight/power/safety are not issues, hardware is much MUCH cheaper than coder time.
Java isn’t useless…(It’s not JS.)
Even Python has a place…
Even VBA…
But all coders should know at least one architecture assembly…even if it’s 6502.
Learning a new architecture costs money too…I digress.
The datasheets of AVR MCUs are one of the best. A lot of explanation of how the peripherals work. Other manufacturers just dump a list of registers with brief descriptions and let you figure it out yourself.
Plus, for non-professionals, the huge user base of same provides a lot of help and example code to examine.
Datasheets of the AVR’s are quite bad. Instead of just writing what the thing does, they have pages long of gibberish of how they intend to use some obscure functions. (Take for example the MPCM bit (multi processor communication for the UART). They could have explained that in 3 lines, but they need multiple pages. Such information should not be put into a datasheet, but in some separate manual or user guide. The old datasheets (20+ years ago) were quite good though. Pretty close to concise without getting obscure.
But still, the AVR’s are pretty simple processors and relatively easy to understand. It is completely bonkers though that the have a “tiny” and a “mega” series, and that there are lots of incompatibilities in peripherals, even between similar AVR’s, or even in the same package.
It’s such a relief to read a description of how a timer peripheral works, and then a note that this processor has 5 of the same timer peripherals. But not with AVR’s. Even if it has two or more timers, they are likely all different. This is a huge waste of human effort during development (Does this or that timer have the extra compare C register), and it also makes it nearly impossible to write library code that works on a bunch of similar processors.
on the off chance that you’re insulting PIC datasheets i’m here to tell you
nuh uh they’re awesome too
Significant discussion, including “why is digitalWrite() slow” can be found here: https://forum.arduino.cc/t/maximum-pin-toggle-speed/4378 (From 2008!)
It doesn’t get really sad till some of the newer architectures decide they need to duplicate the side-effects of the AVR (notably: “if you digitalWrite(pin, HIGH) while the pin is in INPUT mode, that should turn on the input pullup resistor.”)
That, and the Arduino organization’s general unwillingness to include performance improvement changes :-( (There are now “many” implementations of “digitalWriteFast()”, none of which have been accepted by Arduino.)
Also, avr-gcc has __builtin_avr_delay_cycles(), so there’s no need to write assembly code to even out your square wave.
“they’ve probably done more to make embedded programming accessible to more people than anything else in the history of the field.”
Would be a good article and comments around this.
A lot of PIC, MIT handyboard got me into robotics, picaxe was a slightly earlier abstracted Arduino concept for sure, TI Launch pad for MSP low power work, adjacent Lego mindstorms
Basic STAMP FTW! Got me into microcontrollers because it sucked so badly I looked into what it was made from, and the rest is history. Oh, that and Microchip’s early application notes, such a delight to read!
I got into AVR programming on bare metal because it was cheaper than an Arduino.
The Arduino “works” on a level where you have people who understand absolutely nothing about programming, like “What’s a macro? What is a register?”, and the point of it is to keep them that way for as long as possible by not explaining anything. That is of course to keep people coming back to Arduino.
MIT handy board was 68HC11 based wasn’t it? I once wrote a firmware update (called SmoothPWM) that implemented pulse density modulation instead of PWM to achieve 256 PWM steps instead of 8.
https://www.cs.uml.edu/~fredm/handyboard.com/oldhb/misclink/index.html
I recommend flashforth as a great next step beyond the arduino ide. Get it at flashforth.com
This topic returns from time to time:
https://hackaday.com/2010/01/06/arduino-io-speed-breakdown/
But it only shows how good platform Arduino is. Despite it’s age and prophecies it’s still popular.
It makes sense the AVR is still used. For many low level applications it is fast enough. 16MHz with simple code allows sub millisecond response time for many signals. 32KiB FLASH is plenty for many simple applications.
It lacks the processing power and memory for handling graphical LCDs. It is slow at floating point. And it is not the most power efficient MCU so it’s not ideal for battery powered applications. But for many applications this is not an issue.
Every time this comes up – Arduino AVR functions/libraries being slow or poorly optimized for x – I have to point out – you don’t have to use the built in functions in the Arduino IDE. You can write bare metal C just fine, the only price you have to pay with the Arduino IDE and AVRs is timer0, and a couple of interrupts.
Also, its not necessarily all or nothing – you can use some libraries, and lower level code, but you have to be aware of what resources/peripherals/dependencies the library uses (which is handy because it gives one the habit of actually checking what the library is doing rather than treating it as a black box).
And as many have stated here – Arduino is about education and convenience, not speed, power optimization, just knocking something up for testing or prototyping. Right tools, for the right job.
Saying Arduino ruined embedded programming is like saying home cookbooks ruin gourmet cooking. Each serves a purpose, and can be a stepping stone to the other.
This knowledge elitism helps no-one and dissuades people from following their interests. You need to stop.
The ONLY thing Arduino did for people is to teach them how to do things the wrong way.
It also swamps the internet and git sites with badly written code.
Did you prefer PIC16F84/A, BasicStamp or 8052 AH BASIC though?
I loved the PIC16C84 and its newer versions but it had some drawbacks.
Many projects were available as HEX files only and the PICs all had a slightly different assembly language.
This is not speeding up Arduino. It is just throwing the Arduino ecosystem overboard and do the register calls yourself directly.
Maybe have a look at the Teensy code. There Paul Stofregen did some clever trickery to speed up a lot of the calls, but he stays within the Arduino ecosystem. If you look at the digitalWrite calls, they get replaced with direct port manipulations through the use of c++ template trickery.
You can toggle a pin by writing a 1 to the pin register of an AVR MCU. This trick is very useful. No need to use read-modify-write.
PORTB |= (1<<bitpos); doesn’t do read-modify-write, on most AVRs and most ports.
It gets optimized to a single “sbi” instruction.
If PORTB&(1<<bitPos) is an output, then PINB |= (1<<bitPos) will achieve PORTB ^= (1<<bitPos), toggling the output, with a single SBI instruction. This is what ‘C’ meant in their comment.
PINB = (1<<bitPos)
Except that one (“=”, rather than “|=”) will take at least two instructions and a register.
(although it could also toggle more than one bit at a time.)
Arguably, the optimization of “SFR |= bit” to an SBI instruction is incorrect behavior. It gets messy when read and write values are inconsistent (as they are here, with PINB.)
Using |= will toggle all pins that have a 1 in the pin register, right?
Also it doesn’t need 2 instructions. Only 1 register that needs to be initialized once. The compiler doesn’t have to load that register every single time.
I like Arduino.
It works the same on a lot of platforms and allows me to get started quickly without having to learn everything about acprocessors init process or specific hardware. It’s got vast library support, and many of those libraries are readable in account of being very small.
Later, when I need better performance, or hardware specific stuff, I can dig deeper on that one topic and the rest of my Arduino code still works fine.
I wish it had a debugger, and some command line tools and more traditional IDE stuff, but I prefer their striped down environment to the mess that is Eclipse any day.
It would be nice if other development environments had easy ways to incorporate Arduino code, but the last time I looked, it was too clumsy to get working. Maybe that has changed?
Arguably, it SHOULD, but it’s optimized to an SBI instruction, which doesn’t do a “real” RMW cycle on the register.
I don’t know what’s worse…
That this trick is still “discovered” in 2025, or that Arduino didn’t update it’s IO libs for decades.
They could at least provide optimisation for low end 8 bits mcu. It would prevent the DigitalPinWriteFast() forest.
If the Arduino software library were made faster, the hardware would be much less reliable.
Eric Bogatin often uses Arduino as an example of bad-but-good-enough PCB layout for his hardware students. His latest appearance on Robert Ferenec’s channel ( https://www.youtube.com/watch?v=X-qubBLJDD8&lc=UgyWq3GzTF6a4gJcVkl4AaABAg
Do You Design Connector Pinout Correctly? | Eric Bogatin — perhaps skipping ahead to ~18 minutes) is an example.
With the default Arduino board, and a reasonable (perhaps not normal, but reasonable) use of of pin headers, you get more than enough noise to cause problems if you use the fast versions. The extra checks and serialization and such slow the switching enough that this isn’t usually a problem in practice.
But if they rewrote the libraries to encourage as-fast-as-possible software, the constraints on hardware layout would get much tighter.
personally, i hate arduino. because i already knew embedded development before i met it. and because PIC is better than AVR. and because i don’t like the arduino boards i’ve happened across.
but i’m torn about its overall value for other people or the community at large. a good example is Marlin (3D printer firmware). i’ve got 10 year old Marlin source sitting around — hopefully it’s improved in the last decade but honestly i don’t imagine it has :)
the first thing i ran into with Marlin is that it had some incidental dependency on some quirk of the arduino C library too, which bit me because i used some AVR C library that debian installed instead — i’d rather do just about anything than install some IDE with an attached SDK. that’s really what i don’t like about Arduino. simply by deciding to use reasonable commandline tools i’ve already broken their model more severely than if i “#define digitalWrite digitalWriteFast”.
Marlin uses digitalWrite, and also has a fastio.h with a direct memory-mapped-IO interface. that strikes me as pointless complication. there’s a lot of pointless complication in Marlin.
Marlin isn’t written by programmers, per se. everyone comes at Marlin and does the least-effort hack to get their printer to work, and then loses interest. so it’s very much ‘hacked’ instead of ‘developed.’ people intermittently try to do various merges and clean up but the community doesn’t seem to be there for it.
basically, i don’t like Marlin. and the way it uses Arduino is just another thing on the list of why i don’t like it.
but! given the quality of software development it’s seen, could Marlin even exist without Arduino? it seems to me like many of the developers along the way weren’t up to the task of, for example, reading a datasheet or configuring a proper SDK. but yet we did get valuable work from them. and the ‘hats’ — overall i don’t like the arduino form factor or boards but where would 3d printing be without the RAMPS hat?
and here i am, i got a new printer, and lo, it is using Marlin too. thankfully, i haven’t had cause to modify it!
so it definitely seems to have had its use
The only IDE I don’t like is the atmel based on VS.
Reminds me of discussions about Python. If you write more than 500 lines of code you are using the wrong tool.
And yes, guilty as charged myself.
Why not go with an UDOO RYZEN Bolt V8 SBC Maker Board and use 80586 assembly language to program it as it will be much faster
Heck of a lot of snobbery here. It’s funny all these amazing, “bare metal C” programmers who look down their noses at the Arduino ecosystem never seem to scroll past an Arduino posting here on HackADay..
haha there’s a good reason for that…i never thought of arduino as analogous to windows but…
in 1993 i was ambivalent towards windows. i had used DOS a lot, win3.1 a little, and linux/unix not-at-all. and then by 1996 i hated windows passionately, because i had used win95 enough to know how slow and opaque and non-debuggable and developer-unfriendly it is. and on the other side, i had used linux enough to know that progress (“32-bit protected mode”!!) doesn’t have to be two steps backwards. and i hated windows passionately into the aughts, as i continued to run into the long arm of microsoft…for example, in 2001 i had a fine job but then i got ‘promoted’ to windows tech support and had to quit. in 2003, i was a professional web developer and MSIE was the bane of my existence. in 2004, i made a javascript app ‘just for fun’ and again MSIE was punishing me.
and then POOF it disappeared. i didn’t even notice until sometime around 2010 i noticed i just don’t hate windows anymore. it’s not much of a mystery — i basically haven’t had any contact with any form with windows since 2005ish. i don’t have any programs that force me to maintain windows at home just to use them. as a web developer, edge is chrome is safari. whenever i need a ‘least common denominator’ computational environment — which used to mean windows — i reach instead for android (which i do hate now).
so i don’t do battle with arduino very often. but in recent memory, definitely more often than with windows. so today i hate arduino more than i hate windows :) (arduino is much less bad than windows is, though)
though i tried to be balanced in my criticism of arduino here…it really is harmful in some ways, and beneficial in others. but it’s definitely something that evokes a response. it’s fresh in my mind.
I remember when we first got a c compiler for the atmel and microchip microcontrollers. I remember cobbling together c functions with pure assembly inside.. so much fun.
