Facebook and Yandex have been caught performing user-hostile tracking. This sort of makes today just another Friday, but this is a bit special. This time, it’s Local Mess. OK, it’s an attack with a dorky name, but very clever. The short explanation is that web sites can open connections to localhost. And on Android, apps can be listening to those ports, allowing web pages to talk to apps.
That may not sound too terrible, but there’s a couple things to be aware of. First, Android (and iOS) apps are sandboxed — intentionally making it difficult for one app to talk to another, except in ways approved by the OS maker. The browser is similarly sandboxed away from the apps. This is a security boundary, but it is especially an important security boundary when the user is in incognito mode.
The tracking Pixel is important to explain here. This is a snippet of code, that puts an invisible image on a website, and as a result allows the tracker to run JavaScript in your browser in the context of that site. Facebook is famous for this, but is not the only advertising service that tracks users in this way. If you’ve searched for an item on one site, and then suddenly been bombarded with ads for that item on other sites, you’ve been tracked by the pixel.
This is most useful when a user is logged in, but on a mobile device, the user is much more likely to be logged in on an app and not the browser. The constant pressure for more and better data led to a novel and completely unethical solution. On Android, applications with permission to access the Internet can listen on localhost (127.0.0.1) on unprivileged ports, those above 1024.
Facebook abused this quirk by opening a WebRTC connection to localhost, to one of the ports the Facebook app was listening on. This triggers an SDP connection to localhost, which starts by sending a STUN packet, a UDP tool for NAT traversal. Packed into that STUN packet is the contents of a Facebook Cookie, which the Facebook app happily forwards up to Facebook. The browser also sends that cookie to Facebook when loading the pixel, and boom Facebook knows what website you’re on. Even if you’re not logged in, or incognito mode is turned on.
Yandex has been doing something similar since 2017, though with a different, simpler mechanism. Rather than call localhost directly, Yandex just sets aside yandexmetrica.com for this purpose, with the domain pointing to 127.0.0.1. This was just used to open an HTTP connection to the native Yandex apps, which passed the data up to Yandex over HTTPS. Meta apps were first seen using this trick in September 2024, though it’s very possible it was in use earlier.
Both companies have ceased since this report was released. What’s interesting is that this is a flagrant violation of GDPR and CCPA, and will likely lead to record-setting fines, at least for Facebook.
What’s your Number?
An experiment in which Google sites still worked with JavaScript disabled led to a fun discovery about how to sidestep rate limiting and find any Google user’s phone number. Google has deployed defensive solutions to prevent attackers from abusing endpoints like accounts.google.com/signing/usernamerecovery. That particular endpoint still works without JS, but also still detects more than a few attempts, and throws the captcha at anyone trying to brute-force it.
This is intended to work by JS in your browser performing a minor proof-of-work calculation, and then sends in a bgRequest token. On the no-JavaScript version of the site, that field instead was set to js_disabled. What happens if you simply take the valid token, and stuff it into your request? Profit! This unintended combination bypassed rate-limiting, and means a phone number was trivially discoverable from just a user’s first and last names. It was mitigated in just over a month, and [brutecat] earned a nice $5000 for the effort.
Catching Reflections
There’s a classic Active Directory attack, the reflection attack, where you can trick a server into sending you an authentication, and then deliver that authentication data directly back to the origin server. Back before 2008, this actually worked on AD servers. The crew at RedTeam Pentesting brought this attack back in the form of doing it with Kerberos.
It’s not a trivial attack, and just forcing a remote server to open an SMB connection to a location the attack controls is an impressive vulnerability. The trick is a hostname that includes the target name and a base64 encoded CREDENTIAL_TARGET_INFORMATIONW all inside the attacker’s valid hostname. This confuses the remote, triggering it to act as if it’s authenticating to itself. Forcing a Kerberos authentication instead of NTLM completes the attacker magic, though there’s one more mystery at play.
When the attack starts, the attacker has a low-privileged computer account. When it finishes, the access is at SYSTEM level on the target. It’s unclear exactly why, though the researchers theorize that a mitigation intended to prevent almost exactly this privilege escalation is the cause.
X And the Juicebox
X has rolled out a new end to end encrypted chat solution, XChat. It’s intended to be a significant upgrade from the previous iteration, but not everyone is impressed. Truly end to end encryption is extremely hard to roll out at scale, among other reasons, because users are terrible at managing cryptography keys. The solution generally is for the service provider to store the keys instead. But what is the point of end-to-end encryption when the company holds the keys? While there isn’t a complete solution for this problem, There is a very clever mitigation: Juicebox.
Juicebox lets users set a short PIN, uses that in the generation of the actual encryption key, breaks the key into parts to be held at different servers, and then promise to erase the key if the PIN is guessed incorrectly too many times. This is the solution X is using. Sounds great, right? There are two gotchas in that description. The first is the different servers: That’s only useful if those servers aren’t all run by the same company. And second, the promise to delete the key. That’s not cryptographically guaranteed.
There is some indication that X is running a pair of Hardware Security Modules (HSMs) as part of their Juicebox system, which significantly helps with both of those issues, but there just isn’t enough transparency into the system yet. For the time being, the consensus is that Signal is still the safest platform to use.
Bits and Bytes
We’re a bit light on Bits this week, so you’ll have to get by with the report that Secure Boot attacks are publicly available. It’s a firmware update tool from DT Research, and is signed by Microsoft’s UEFI keys. This tool contains a vulnerability that allows breaking out of it’s intended use, and running arbitrary code. This one has been patched, but there’s a second, similar problem in a Microsoft-signed IGEL kernel image, that allows running an arbitrary rootfs. This isn’t particularly a problem for us regular users, but the constant stream of compromised, signed UEFI boot images doesn’t bode well for the long term success of Secure Boot as a security measure.
The entire concept of WebSockets strikes me as a bad idea. I know it’s useful for some design patterns (especially evil ones) but that doesn’t make it a good idea. Being able to connect to localhost (or any loopback address) only makes it that much worse.
So:
Facebook can’t be trusted but tidies up when it’s caught actively betraying its users’ privacy
Google can’t be trusted but seems to be trying to keep its users’ data private
Microsoft can’t be trusted but seems to be trying to keep its users’ data private
Twitter can’t be trusted but promises it can be trusted
And last but not least, Microsoft can’t be trusted to be a source of trust
Corporations will sink to the lowest level of criminality that the law allows.
Strong and enforced regulation is what keeps us alive.
It’s almost a given that an entity under heavy pressure to grow or to compete will use any allowed tools. Even antisocial ones. And the decision makers are generally shielded from the legal consequences of their decisions. It’s definitely a recipe for a race to the bottom.
What makes us think the government is any different? The problem is people with no moral standards, and both corporations and government are made from the same people.
The solution is people who actually have ethical standards.
LOL
Use AI to fix the problem of ethics…no ethics, no problem!
I don’t get a say about who runs Microsoft.
I do get some, I minor, say about who is in my government.
A corporation has exactly one goal, profit.
A government has completely different goals.
That is why a government CAN be trustworthy and CAN act in your interest. (Which is not the same as saying any particular one is or does.)
Corporations can also be trusted, just like a fire can, but will never act in your interest unless it furthers their own.
Fire is actually a VERY good analogy for how a corporation acts, and how we must treat them.
Fire must be controlled, or it will consume everything, end to it’s own detriment.
The government acts in ITS interest only. You can benefit for it if you belong to the party in power, or if your vote can be bought (with your own taxes, or the taxes of other people, of course) for voting that same party.
As we are clearly are seeing here in Spain right now.
“Truly end to end encryption is extremely hard to roll out at scale, among other reasons, because users are terrible at managing cryptography keys.”
Ah QKI can’t get here soon enough.
Still need keys. Still need passwords.
So, just write on a sticky note :) . Can’t trust storing in cloud or your computer.
Not sure it will help. The only reason end to end encryption is being rolled out at scale by companies like X and facebook is they’ve already backdoored it by sticking a helpful AI agent at both ends to report back to them. The encryption is only there so they get to hoard the data, your privacy has nothing to do with it.
x86 TPM, StrongBox SE and TEE Android, SEP IOS and MacOS. Use post-quantum ciphers and write everything but UI in Rust, and use isolation for attestation sp when they get phished, warez malware, or a zero-click dropper the lifted pass or cookie can’t be used..
Yeah the challenge is protecting people without attention spans on computers and the internet.. Even DARPA scientists get primitive malware after being phished..
I am going to have to disagree with you. The very first tracking pixel I heard about was … let me give you a fictious example.
A HP CEO sends out an email to all the senior management and HP fellows. And the email invokes how the spirits of Bill Hewlett and David Packard if they were alive today would fully endorse the cheaper quality products and the reinvestment of profits into increasing the share price. Included in this html email is a link to an external website which hosts nothing but a single white pixel with a unique filename.
That webservers log file can then track if that email was forwarded and then read by a reporter at the New York times or the guardian newspaper or any non Hewlett Packard recipients.
My point is that a tracking pixel does not need Java enabled to work.
^ this, a raw tracking pixel alone is just an unobtrusive way to send an HTTP request to a server and in itself contains no javascript or anything else, at most it will pass along any cookies held for that request and can include a query string or code in the URL.
I’d hope HaD journos would understand basic internet stuff.
“invisible image” If it’s invisible that should make it easy to find, just eliminate all the visible stuff. Perhaps “one-pixel sized image of one pixel”?
The “link to a webpage” thing strikes me as being an extra step. Perhaps I misunderstand.
May I suggest a more appropriate for TwiXXer? TwiXXer!
It’s X and Twitter and no more mistaking it for X the windows manager system…
I hope fans of Raider won’t feel discriminated against…
(I’m actually surprised I still cant find this word “properly used” online )
It’s Xitter (pronounced “shitter”). A person who posts has Xitted.
Hmm…
Xitter is less “pronounceable” in many other languages I think.
Someone is twiXXing
He/She/They just twiXXed
If there was one person in the world whose business is named after an Ex (aka his string of paramours and business partners). Lol.
Jokes on Meta, I actively un-install Facebook app. It sucks anyway on my Fold2 with 500-600DPI screen settings.
I haven’t left SecureBoot on if I could turn it off in about 8 years. Otherwise I hope MOK manager is available and use the Ventoy Shim
man… in chrome, i accept that there’s no privacy because noscript adblock etc are just too much work for me. but when i get html email, i read it in lynx. so my one bank sends me an email every couple of months telling me i forgot to load their tracking pixels. they force me to go through some confirmation process to re-add my email address. the other bank switched me to paper statements!
so periodically i click on the tracking pixels in lynx just to head this off. there’s at least two in each email. of all the organizations, i really would have hoped banks would be most appreciative of me not using a full browser to read email.
But they’re invisiboo! How do you click on them?!
if you press ‘*’ in lynx, it includes links for each of the img tags. i just download the file and then don’t save it.
Recently used Discord again (reluctantly) in a browser and noticed that µMatrix showed some stuff trying to access @ 127.0.0.1
Didn’t dug deeper but looks like Discord might try this too (accessing the Desktop / SPhone app).
Webrtc is cool and opens the way to applications that aren’t really possible otherwise. This will lead to further restrictions for developers, when the real solution is to designate facebook as a criminal organization and blacklist them from any app store
