Fission Simulator Melts Down RP2040
Screenshot of Pi Pico RMBK simulator
We’ve seen a lot of projects based on the Pi Pico, but a nuclear reactor simulation is a new one. This project was created by [Andrew Shim], [Tyler Wisniewski] and another group member for Cornell’s ECE 4760 class on embedded design (which should silence naysayers who think the Pi Pico can’t be a “serious” microcontroller), and simulates the infamous soviet RMBK reactor of Chernobyl fame.
The simulation uses a 4-bit color VGA model. The fission model includes uranium fuel, water, graphite moderator, control rods and neutrons. To simplify the math, all decayed materials are treated identically as non-fissile, so no xenon poisoning is going to show up, for example. You can, however, take manual control to both scram the reactor and set it up to melt down with the hardware controller.
The RP2040’s dual-core nature comes in handy here: one core runs the main simulation loop, and the main graphic on the top of the VGA output; the other core generates the plots on the bottom half of the screen, and the Geiger-counter sound effect, and polls the buttons and encoders for user input. This is an interesting spread compared to the more usual GPU/CPU split we see on projects that use the RP2040 with VGA output.
An interesting wrinkle that has been declared a feature, not a bug, by the students behind this project, is that the framebuffer cannot keep up with all the neutrons in a meltdown simulation. Apparently the flickering and stuttering of frame-rate issues is “befitting of the meltdown scenario”. The idea that ones microcontroller melts down along with the simulated reactor is rather fitting, we agree. Check it out in a full walkthrough in the video below, or enjoy the student’s full writeup at the link above.
This project comes to us via Cornell University’s ECE 4760 course, which we’ve mentioned before. Thanks to [Hunter Adams] for the tipoff. You may see more student projects in the coming weeks.
11 thoughts on “Fission Simulator Melts Down RP2040
  1. man the simulation of reaction byproducts is the only interesting thing imo. without that, it’s just remove rods to increase temperature. you effectively pretend the reactor is stateless, but real reactors very much are not
    1. Very true, but these are computer science grads doing a final project to show off their embedded programming chops, not physicists or nukeEs, so we can perhaps find it in ourselves to forgive them.
        1. Apologies, you are right, I should have said emoji
          It wasn’t said as a critique per se BTW, more as an insight into my reasoning to show what effect emoji can have. Thought it might be interesting to RoboJ1M since my reaction was not the intent – one assumes.
          Talking of which, I often see people using massive amounts of emoji and I wonder if they think people really appreciate it.
          1. Talking of which, I often see people using massive amounts of emoji and I wonder if they think people really appreciate it.
            I don’t understand because surely takes longer to find the emoji than it does to just type the word. It MUST be quicker to type “pie” than to open a menu, tell it you’re looking for a picture of a pie, then select the pie you want.
Leave a Reply to Tyler AugustCancel reply
