Tiny Tellurium Orbits Atop A Pencil
We like scale models here, but how small can you shrink the very large? If you’re [Frans], it’s pretty small indeed: his Micro Tellurium fits the orbit of the Earth on top of an ordinary pencil. While you’ll often see models of Earth, Moon and Sun’s orbital relationship called “Orrery”, that’s word should technically be reserved for models of the solar system, inclusive of at least the classical planets, like [Frans]’s Gentleman’s Orrery that recently graced these pages. When it’s just the Earth, Moon and Sun, it’s a Tellurium.
The whole thing is made out of brass, save for the ball-bearings for the Earth and Moon. Construction was done by a combination of manual milling and CNC machining, as you can see in the video below. It is a very elegant device, and almost functional: the Earth-Moon system rotates, simulating the orbit of the moon when you turn the ring to make the Earth orbit the sun. This is accomplished by carefully-constructed rods and a rubber O-ring.
Unfortunately, it seems [Franz] had to switch to a thicker axle than originally planned, so the tiny moon does not orbit Earth at the correct speed compared to the solar orbit: it’s about half what it ought to be. That’s unfortunate, but perhaps that’s the cost one pays when chasing smallness. It might be possible to fix in a future iteration, but right now [Franz] is happy with how the project turned out, and we can’t blame him; it’s a beautiful piece of machining.
It should be noted that there is likely no tellurium in this tellurium — the metal and the model share the same root, but are otherwise unrelated. We have featured hacks with that element, though.
Thanks to [Franz] for submitting this hack. Don’t forget: the tips line is always open, and we’re more than happy to hear you toot your own horn, or sing the praises of someone else’s work.
7 thoughts on “Tiny Tellurium Orbits Atop A Pencil
    1. If you read the first line of that page it tells you that tellurium is one of the accepted names, besides tellurian and tellurion.
      1. I thought a Tellurian was like a Tellurite. But I digress. (Dammit Jim, I’m a doctor not an astrophysicist nor a linguist!)
  1. actually it worked with the smaller axle, so it can work perfectly, but it just wasn’t too reliable. One day it worked, and another day the rubber ring kept slipping. So just for demonstration purposes, I used a bigger axle to make it work every day, just not at the right ratio, but that doesn’t make it less impressive.
Leave a Reply to thestoneburnerCancel reply
